Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
Svc lca
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="boarder1995x2" data-source="post: 1240487" data-attributes="member: 23630"><p>The SVC LCA is the same width as a stock Raptor LCA. And you don't need to run their upper for the lower to work. The big benefit to the stock length LCA from SVC is the ability to run a secondary bypass shock behind the coilover.</p><p></p><p> SVC does offer front kits for additional travel that are wider than a stock Raptor. As do many other companies too like RPG BOLT Kit, H&M, Baja Kits, etc.</p></blockquote><p></p>
[QUOTE="boarder1995x2, post: 1240487, member: 23630"] The SVC LCA is the same width as a stock Raptor LCA. And you don't need to run their upper for the lower to work. The big benefit to the stock length LCA from SVC is the ability to run a secondary bypass shock behind the coilover. SVC does offer front kits for additional travel that are wider than a stock Raptor. As do many other companies too like RPG BOLT Kit, H&M, Baja Kits, etc. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
doyouthinkhesawus
mwaite09
rgz
Needalift
richardusmc
HORN HIGH ACES
Spydie35
10SpdsOfFury
raptorrecon
Swacer_2
Brandon dobar
Helopilot
delemdry
22R37
DesertRap34
AL73
sheefo2k
Spike Spiegel
Doubleeaz
alockbox
24NoVARaptor
DFS
IHAVETWO
High Sierra
jdm_sixtwo
91Eunos
BigBlue20
MajorAR
arquatro
nelsonr103
anb
Canuck714
choboja
MurderedOutSVT
Specialtyperformanceparts
FGHT ON
FP_RPTR
lrg702
shigman
Lifted&slifted
Dbone
vill
willwork04
ECW
Tvd17
Sergio212
jekyll537
Hawkracer
taquitos
New recaros
... and 76 more.
93,215
56,495
bolilly
Forums
Svc lca
Accept
Learn more…
