Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford SVT Raptor General Discussions [GEN 1]
Stupid stock jack won't fit back under seat
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="phydough" data-source="post: 640530" data-attributes="member: 57"><p>I cut the front left sidewall in a deep mud hole. Set up to change it on semi firm wet ground, put the jack on a couple of 2x6's, as more weight got on the jack, the 2x6's shifted slightly, sinking one side. The jack bent into a mild ( shape and locked in place, no up and no down. I needed the 2x6's out, so I drove it off the broke jack. Out came the the Hi-Lift to do the job right. </p><p>For the record, the KC Hilites light bar can indeed be used as a Hi-Lift jacking point, without too much bending.</p><p>I have used the stock jack to change tires about 6 times now, the only difference was, those were all on the rear and this time was on the front, on unstable ground.</p></blockquote><p></p>
[QUOTE="phydough, post: 640530, member: 57"] I cut the front left sidewall in a deep mud hole. Set up to change it on semi firm wet ground, put the jack on a couple of 2x6's, as more weight got on the jack, the 2x6's shifted slightly, sinking one side. The jack bent into a mild ( shape and locked in place, no up and no down. I needed the 2x6's out, so I drove it off the broke jack. Out came the the Hi-Lift to do the job right. For the record, the KC Hilites light bar can indeed be used as a Hi-Lift jacking point, without too much bending. I have used the stock jack to change tires about 6 times now, the only difference was, those were all on the rear and this time was on the front, on unstable ground. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
ToadSmasher2K1
Badboy4fun_wa
RRick
The Car Stereo Company
bakwaas4eva
PNTitBLK
GreenGoblin
dk311_
LeadFootSweet
toxwaste
M3sparky
BushwiickBill
elpechedepeche
Johnny@Apollo-Optics
Jenner1
hsoonalmulla
TK-421
18R34
CecilK12
MZRaptor72
Mossy 150
Wristdoc
TexnRalf
aakbar_828
cptguiness
jdm_sixtwo
JeffroMc
jaguirrefitness
cswht
Bowlmsc
2011_Shelby
mleaky
GEN3LV
njhummer18
2012SCSVT
Gibsonm21
debauch
Nood1es
MEIRONMAN207
BadWRP
Needalift
Rekkr
970rap
Crywolf4
Tonecapone
EliteAGDan
3Dog
tonythis
zachery55
Bronze
... and 41 more.
93,302
56,593
sdavis007
Forums
Accept
Learn more…
