Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Lighting Modifications Forum [GEN 1]
Stock 3rd Brake Light Sealing
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Agent 00 L" data-source="post: 1253626" data-attributes="member: 15203"><p>I went full monty on this little project.</p><p></p><p>I put about 1/4" of expoy in the holes, wasn't sure how long the screw was.</p><p></p><p>I then ran some silicone around the inside edge where the gray pastic meets the clear, you can see the gap in there.</p><p></p><p>Then when I installed it I put a small bead under the head of the screw. Then once it was on the truck I put another bead around the head of the screw to seal it.</p><p></p><p>Lastly I ran a bead around the outside of the light to seal it to the truck. </p><p></p><p>Its going to be a bear to get it back off, but I am not counting on doing that with it sealed up.</p><p></p><p>One thing I did notice was that as i was puttting it on it was taking a good bit of force to compress the neoprene gasket and draw the light onto the truck. This might be the cause of the cracking issues people seeing. I went easy on the tension and sealed the gap with silicone.</p><p></p><p>It rained a good bit when I was home and it looked good.</p></blockquote><p></p>
[QUOTE="Agent 00 L, post: 1253626, member: 15203"] I went full monty on this little project. I put about 1/4" of expoy in the holes, wasn't sure how long the screw was. I then ran some silicone around the inside edge where the gray pastic meets the clear, you can see the gap in there. Then when I installed it I put a small bead under the head of the screw. Then once it was on the truck I put another bead around the head of the screw to seal it. Lastly I ran a bead around the outside of the light to seal it to the truck. Its going to be a bear to get it back off, but I am not counting on doing that with it sealed up. One thing I did notice was that as i was puttting it on it was taking a good bit of force to compress the neoprene gasket and draw the light onto the truck. This might be the cause of the cracking issues people seeing. I went easy on the tension and sealed the gap with silicone. It rained a good bit when I was home and it looked good. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
never_summer
BoostCreep
HighSpeedLowDrag
Rednose
93,202
56,485
bjorn-dpc
Forums
Accept
Learn more…
