Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Lighting Modifications Forum [GEN 1]
Six light switch.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="S197Mach1" data-source="post: 1028369" data-attributes="member: 14889"><p>Changing my KC cubes out for a flex light bar. I had the cubes on number 4 which is 10 amps and the cubes only needed 8 and some change. The light bar requires 10 amps. Can I reuse 4 or should I go to the next higher switch. I don't know if I would need room or if 10 amps draw and a 10 amp fuse is ok? </p><p></p><p></p><p>Edit: six should read stock. </p><p></p><p>Sent from my iPhone using Tapatalk</p></blockquote><p></p>
[QUOTE="S197Mach1, post: 1028369, member: 14889"] Changing my KC cubes out for a flex light bar. I had the cubes on number 4 which is 10 amps and the cubes only needed 8 and some change. The light bar requires 10 amps. Can I reuse 4 or should I go to the next higher switch. I don't know if I would need room or if 10 amps draw and a 10 amp fuse is ok? Edit: six should read stock. Sent from my iPhone using Tapatalk [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Haydel53
CVP33
erikz
Powerlies
Stingray23
shang
RaptorJohnny2022
Swacer_2
RogueClimber
isis
RaptorAU
RCorsa
shigman
JHughes629
HAP
aspenchournos
GordoJay
MurderedOutSVT
MCJEFE
Neens
jdm_sixtwo
RaptorJoe331
06z
silvertige
wweaver
jasonzee
jhgrossi2004
mprice1234
TomDirt
JDMCTR00
perry
ToadSmasher2K1
pat247
Barr993
TAC71
DaveInMn
Zeusmotorworks
HTXShadow
Raptor_NV
WNCHSTR96
alphablue
Winchester30
MSP
lgotye
quattrojim
Marlboroman
Mossy 150
dsa6953
Bozz
jimmytheone
... and 16 more.
93,275
56,567
erikn
Forums
Six light switch.
Accept
Learn more…
