Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
School me - Icon 3.0's
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ntm" data-source="post: 1131227" data-attributes="member: 2412"><p>3.0's/bumps/deavers make the otherwise stock raptor capable of traveling about 30% faster over small to medium sized terrain.</p><p></p><p>They will not provide a smoother ride at lower speeds, in fact I found the icons much, much worse for ride quality at lower speeds. The fox 3.0's are vastly better in this regard.</p><p></p><p>Changing compression on the bypass will do very little when towing, as the shock will likely not be in the ride zone anyways. A +3 deaver is the best solution for too much squat.</p></blockquote><p></p>
[QUOTE="ntm, post: 1131227, member: 2412"] 3.0's/bumps/deavers make the otherwise stock raptor capable of traveling about 30% faster over small to medium sized terrain. They will not provide a smoother ride at lower speeds, in fact I found the icons much, much worse for ride quality at lower speeds. The fox 3.0's are vastly better in this regard. Changing compression on the bypass will do very little when towing, as the shock will likely not be in the ride zone anyways. A +3 deaver is the best solution for too much squat. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
julien194b
2010 Shelby
93,180
56,460
khunter
Forums
Accept
Learn more…
