Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford F-150 Raptor General Discussions [GEN 2]
Rokblokz with Husky wheel well liners
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Seven" data-source="post: 1227132" data-attributes="member: 24764"><p>I just picked up a set of Rokblokz and a few weeks ago I installed the Husky liners. Yes, the liners were a pita to install and I ended up trimming quite a bit to get them seated correctly. </p><p></p><p>I just installed the front Rokblokz and now I'm wondering about the rears. It seems you have to pull the bottom two screw retaining clips to push on the new metal screw holders. Then the top mounting hole, you need to drill a 1/8" hole and also insert a clip. </p><p></p><p>Has anyone else installed the wheel liners and then installed the flaps? Any issue with moving the liners a bit out of the way to get the Rokblokz installed or is there no issue at all and the install should go smoothly. </p><p></p><p>Let me know. Thanks.</p></blockquote><p></p>
[QUOTE="Seven, post: 1227132, member: 24764"] I just picked up a set of Rokblokz and a few weeks ago I installed the Husky liners. Yes, the liners were a pita to install and I ended up trimming quite a bit to get them seated correctly. I just installed the front Rokblokz and now I'm wondering about the rears. It seems you have to pull the bottom two screw retaining clips to push on the new metal screw holders. Then the top mounting hole, you need to drill a 1/8" hole and also insert a clip. Has anyone else installed the wheel liners and then installed the flaps? Any issue with moving the liners a bit out of the way to get the Rokblokz installed or is there no issue at all and the install should go smoothly. Let me know. Thanks. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
SeasickLI
stevenstommyboy1
Mike27t
fordfreek
MFouts
DDD2019
edglock21
Slobojin
FJohnny
dillard09
s17w
Rptrrob702
ss55539
pat247
Tbogo
Philipp_Raptor
oliverb
Baja Designs
Roscoe S
Frogger22
toxwaste
Kyle@Apollo-Optics
BadWRP
eSos55555
Crywolf4
Pyro3601
MJLGUTH
samwelll
GATOR22
Dev
AfterMidnightRambler
John Liu
HighwaySentinel
DFS
Drkknght
Sbrewer
flyitaway
nikhsub1
lima_delta_82
socal raptor
Tristan Shepersky
KOBRA2848
cmc21
John813
taquitos
hamster
ToadSmasher2K1
kylesatx
Emersonvl74
Noplacelikeloam
... and 41 more.
93,304
56,593
sdavis007
Forums
Accept
Learn more…
