Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Lighting Modifications Forum [GEN 1]
Rigid Industries Light Bar Trouble
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="BAD454SS" data-source="post: 1128182" data-attributes="member: 18546"><p>Check your Aux 1 relay in fuse box could be hanging up. Could be a bad connection where you spliced the wires together. Either under dash or in egine compartment .Can you make it not turn on when your at home in the driveway? If you can, i would try moving wires and splices and giving the relays a tap. To see if it then powers up the light bar. Worst case switch to aux 2 and see if it works. Another idea wire to your battery turn on and off if it screws up then that elimanates annything with truck wiring.</p></blockquote><p></p>
[QUOTE="BAD454SS, post: 1128182, member: 18546"] Check your Aux 1 relay in fuse box could be hanging up. Could be a bad connection where you spliced the wires together. Either under dash or in egine compartment .Can you make it not turn on when your at home in the driveway? If you can, i would try moving wires and splices and giving the relays a tap. To see if it then powers up the light bar. Worst case switch to aux 2 and see if it works. Another idea wire to your battery turn on and off if it screws up then that elimanates annything with truck wiring. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
shigman
B boyes
elpechedepeche
Advcgh
Raptor Harris
Reptar854
Sean76710
BT-Phx
bigjava2002
Slobojin
Matmanand4
RobSpring661
WhiskeyTangoGTFO
ChevyLee
LayinWatts69
MurderedOutSVT
e10tran
BadWRP
pat247
Latchkey Kid
Bu3askoor
MIK3
awd5906
RaptorFun
Tyler Gibson
Chewie
Teledatgeek
WNCHSTR96
Ryan Voight
downforce137
Tbutkus
Eisner62
houtex1
RaptorRapture
Braaaaptor
MDJAK
04Ram2500Hemi
Highwayman
GordoJay
KingKoopa17
LambSVT
Jakenbake
raptorgroyper
crgrossett
Jason Booher
eljefe_tx
JohnyPython
kandewinn
pirates1456
Solidred
... and 19 more.
93,193
56,469
ngodavid23
Forums
Accept
Learn more…
