Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
Right Front suspension noise
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="2baddogs" data-source="post: 1140907" data-attributes="member: 984"><p><strong>Rattle in the RF hub.</strong></p><p></p><p>I have FOX 3.0's and all is tight. The rattle sound is distinct and is not the Fox valve clunk/click that is common. Sounds like a heat shield rattle but its not all the time... bumps compressing suspension do not make the noise occur, small road imperfections can trigger it but not consistently.</p><p></p><p>I can always duplicate with a low speed hard left turn. Went out last night and had the wife drive about 15mph by me while making a hard left. Definitely coming from the RF hub area. Noticed it for the first time a week ago (2014 w 45k mi with about 5-600 off road miles) and it has gotten slightly louder and more frequent in the last week.</p><p></p><p>No noise in 4x or reversing. </p><p></p><p>It was recommended to me to install the RCV/IWE eliminater kit for the solution.</p><p></p><p><a href="http://www.rcvperformance.com/product-details.aspx?sku=IWE-FD" target="_blank">RCV Ultimate IWE Eliminator Set for Ford Raptor ('10 & Up) & F-150 ('04 & Up)</a></p><p></p><p>My plan is to pull the wheel off and check all bolts and to inspect vaccuum line. Not sure what to do if that is all good...go with the suggestion above, I suppose. I will update the thread if I find anything.</p><p></p><p></p><p>*** Just found this thread and this makes the most sense for my problem, hope it helps someone else. Shout out to OP [MENTION=2727]Mil T[/MENTION]!</p><p></p><p><a href="http://www.fordraptorforum.com/f170/weak-vacuum-line-grinding-noise-fix-24281/" target="_blank">http://www.fordraptorforum.com/f170/weak-vacuum-line-grinding-noise-fix-24281/</a></p></blockquote><p></p>
[QUOTE="2baddogs, post: 1140907, member: 984"] [b]Rattle in the RF hub.[/b] I have FOX 3.0's and all is tight. The rattle sound is distinct and is not the Fox valve clunk/click that is common. Sounds like a heat shield rattle but its not all the time... bumps compressing suspension do not make the noise occur, small road imperfections can trigger it but not consistently. I can always duplicate with a low speed hard left turn. Went out last night and had the wife drive about 15mph by me while making a hard left. Definitely coming from the RF hub area. Noticed it for the first time a week ago (2014 w 45k mi with about 5-600 off road miles) and it has gotten slightly louder and more frequent in the last week. No noise in 4x or reversing. It was recommended to me to install the RCV/IWE eliminater kit for the solution. [url=http://www.rcvperformance.com/product-details.aspx?sku=IWE-FD]RCV Ultimate IWE Eliminator Set for Ford Raptor ('10 & Up) & F-150 ('04 & Up)[/url] My plan is to pull the wheel off and check all bolts and to inspect vaccuum line. Not sure what to do if that is all good...go with the suggestion above, I suppose. I will update the thread if I find anything. *** Just found this thread and this makes the most sense for my problem, hope it helps someone else. Shout out to OP [MENTION=2727]Mil T[/MENTION]! [url]http://www.fordraptorforum.com/f170/weak-vacuum-line-grinding-noise-fix-24281/[/url] [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
NickyF25
Telecaster480
BamaFun
WhiskeyTangoGTFO
Skai
erniecsays
Budget1
Wangchung83
KingKoopa17
OBXRAPTOR17
CruiserClass
ToadSmasher2K1
RiskTkr
Reptar854
mckernan
blazn5667
quattrojim
LibertyDNP
DutchDad
jekyll537
elpechedepeche
bcc
Morrisabm
MZRaptor72
dillard09
Nick@Apollo-Optics
CorbinT
pirates1456
RaptorAU
lakebum
stormyhill
nelsonr103
Stingray23
Speedstr
redsmoke
GordoJay
airn890
zeush22
mprice1234
someday
Keith88
Otis857
HOLLYWOOD 1
LayinWatts69
24NoVARaptor
Evasive
smgilles
DDD2019
LastRapWorld83
navy2x
... and 23 more.
93,186
56,468
ngodavid23
Forums
Accept
Learn more…
