Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Lighting Modifications Forum [GEN 1]
Recon Tail Light Issues
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="bprsnt" data-source="post: 1099917" data-attributes="member: 14245"><p><strong>Gave the Recons one more chance</strong></p><p></p><p>My Recon tail lights were installed by Ford when I bought the truck new.</p><p></p><p>The tail lights have always been glitchy and had intermittent issues from the get go. I noticed in the past that the load resistors Ford installed were taped to the wiring harness. I thought it was strange being there were mounting holes on the resistors to secure them to the truck body.</p><p></p><p>I ended up buying the exact load resistors like SuperBright on Amazon. (Just search 6 ohm 50 watt)</p><p>When I received the resistors there was a warning sticker stating that they MUST be mounted to steel frame or will overheat.</p><p></p><p>I simply mounted the new load resistors on the flat body panel inside behind the tail light and have had ZERO issues since.</p><p></p><p>The resistors are wired in parallel with the signal/Brake light.</p></blockquote><p></p>
[QUOTE="bprsnt, post: 1099917, member: 14245"] [b]Gave the Recons one more chance[/b] My Recon tail lights were installed by Ford when I bought the truck new. The tail lights have always been glitchy and had intermittent issues from the get go. I noticed in the past that the load resistors Ford installed were taped to the wiring harness. I thought it was strange being there were mounting holes on the resistors to secure them to the truck body. I ended up buying the exact load resistors like SuperBright on Amazon. (Just search 6 ohm 50 watt) When I received the resistors there was a warning sticker stating that they MUST be mounted to steel frame or will overheat. I simply mounted the new load resistors on the flat body panel inside behind the tail light and have had ZERO issues since. The resistors are wired in parallel with the signal/Brake light. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Finlay150
MattC1996
Jason Watson
MDJAK
Zeusmotorworks
quattrojim
MurderedOutSVT
NickyF25
Johnny149
93,202
56,485
bjorn-dpc
Forums
Accept
Learn more…
