Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Exterior Modifications Forum [GEN 1]
Rear emblem removal and installation?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Doubleeaz" data-source="post: 52488" data-attributes="member: 1104"><p>If you have the reverse camera, the emblem is two pieces. The bottom piece (mounts to tailgate) is bolted to the tailgate. The top piece (Ford emblem) snaps into the bottom piece. you will have to pry off the top Ford emblem which will most likely damage it too bad to reuse. The tabs that snap into the bottom piece are trashed.</p><p></p><p>If you don't have the reverse camera, the ford emblem is held on by two sided tape. I used a screw driver and placed a rag between the screwdriver and the paint to prevent scratches. It should pry off without a whole lot of effort.</p><p></p><p>Either way, will need to replace the two sided tape on the new tailgate.</p></blockquote><p></p>
[QUOTE="Doubleeaz, post: 52488, member: 1104"] If you have the reverse camera, the emblem is two pieces. The bottom piece (mounts to tailgate) is bolted to the tailgate. The top piece (Ford emblem) snaps into the bottom piece. you will have to pry off the top Ford emblem which will most likely damage it too bad to reuse. The tabs that snap into the bottom piece are trashed. If you don't have the reverse camera, the ford emblem is held on by two sided tape. I used a screw driver and placed a rag between the screwdriver and the paint to prevent scratches. It should pry off without a whole lot of effort. Either way, will need to replace the two sided tape on the new tailgate. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
FP_RPTR
91Eunos
jekyll537
New recaros
JD05
doyouthinkhesawus
Specialtyperformanceparts
ECW
GOTX
OldEngr
FGHT ON
HighSpeedLowDrag
3wheelkhalil
TomDirt
Sever18
taquitos
jcollier_91
MagneticScrew
Royalhawg
Raptor Rob
choboja
AL73
deosulli
raptordawg08
DRC3
Canuck714
DFS
cdelvalle
RabDog
gusser
Burt
BigBlue20
anb
Jakenbake
rbrb
jp1seattle
mwaite09
snt505
01Moch1
Jhollowell
Rapgod
raptordawg1
HighwaySentinel
SeasickLI
JeepSRT8
shigman
MurderedOutSVT
Yan
FmaxTurboSi
Skai
... and 81 more.
93,215
56,495
bolilly
Forums
Accept
Learn more…
