Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Lighting Modifications Forum [GEN 1]
Rear bumper LED's, Starkey harness and OTRATTW switches.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="andreb" data-source="post: 1168249" data-attributes="member: 16801"><p>I saw these LED's installed in a Raptor at the dealer service center (it had a slide-in camper) and thought they'd be handy for hooking up my trailer at night (when I'm late to the races) and when backing up in the dark. </p><p></p><p>Here are the lights and harness I bought:</p><p></p><p>Rigid D-Series Flood - flush mount</p><p><a href="http://www.rigidindustries.com/led-lighting/21211" target="_blank">D-Series | Flood Pair Flush White Black | Rigid Industries</a></p><p></p><p>Starkey Backup/Auxiliary Lighting Wiring & Switch Kit</p><p><a href="http://www.starkey-products.com/truck-suv-backup-reverse-lighting-wiring-switch" target="_blank">Backup/ Reverse Lighting Wiring & Switch Kit - Fits any vehicle!</a></p><p></p><p>Once I got that installed I figured out the switch Starkey includes is made by Carling but can be ordered custom from OTRATTW</p><p><a href="https://otrattw.net/Contura-V-SR/" target="_blank">https://otrattw.net/Contura-V-SR/</a></p><p></p><p>The Rigid LED's come with a decent harness and switch. It's a very universal kit that would cover most installs. What I liked about the Starkey kit is that it was F-150 specific, includes Deutsch DT Series 2-way connectors that match the Rigid LED's and uses a relay to activate the lights. I know the LED's don't draw much current but I typically over-build electrical systems because who knows what this will power in the future.</p><p></p><p>The install was pretty straight forward it just took time. I covered cutting and installing the lights here: <a href="http://www.fordraptorforum.com/f11/cutting-into-rear-bumper-tough-49872/" target="_blank">http://www.fordraptorforum.com/f11/cutting-into-rear-bumper-tough-49872/</a></p><p></p><p>Getting power from the OE fuse box into the Starkey harness is here: <a href="http://www.fordraptorforum.com/f12/using-oe-fuse-block-under-hood-power-50161/" target="_blank">http://www.fordraptorforum.com/f12/using-oe-fuse-block-under-hood-power-50161/</a></p><p></p><p>I didn't want to use the OE upfitter switches for this as I have other plans for those. I decided to place the switch directly below the headlight and dimmer switch. Control wise it seems a logical place to operate them from. It was also a spot that didn't require any cutting or modification of the internal dash structure or bracing. Not the easiest to see as the lower panel slope away from you as you sit in the seat but the switch rocker is almost straight up and down when activated.</p><p></p><p>I had the switches customized so the lower text portion is blue and connected to the dash light dimmer circuit. The upper LED is amber just like the factory switches and illuminates when on. I installed another switch (future project) and blanking plate in a three position switch holder that trims out the cut hole nicely. To wire the switches I replaced the crimped on female spades that came on the Starkey harness with an 8 terminal connector housing and the correct Packard terminals. I can now unplug them easily and never have to worry about the wiring order.</p></blockquote><p></p>
[QUOTE="andreb, post: 1168249, member: 16801"] I saw these LED's installed in a Raptor at the dealer service center (it had a slide-in camper) and thought they'd be handy for hooking up my trailer at night (when I'm late to the races) and when backing up in the dark. Here are the lights and harness I bought: Rigid D-Series Flood - flush mount [url=http://www.rigidindustries.com/led-lighting/21211]D-Series | Flood Pair Flush White Black | Rigid Industries[/url] Starkey Backup/Auxiliary Lighting Wiring & Switch Kit [url=http://www.starkey-products.com/truck-suv-backup-reverse-lighting-wiring-switch]Backup/ Reverse Lighting Wiring & Switch Kit - Fits any vehicle![/url] Once I got that installed I figured out the switch Starkey includes is made by Carling but can be ordered custom from OTRATTW [url]https://otrattw.net/Contura-V-SR/[/url] The Rigid LED's come with a decent harness and switch. It's a very universal kit that would cover most installs. What I liked about the Starkey kit is that it was F-150 specific, includes Deutsch DT Series 2-way connectors that match the Rigid LED's and uses a relay to activate the lights. I know the LED's don't draw much current but I typically over-build electrical systems because who knows what this will power in the future. The install was pretty straight forward it just took time. I covered cutting and installing the lights here: [url]http://www.fordraptorforum.com/f11/cutting-into-rear-bumper-tough-49872/[/url] Getting power from the OE fuse box into the Starkey harness is here: [url]http://www.fordraptorforum.com/f12/using-oe-fuse-block-under-hood-power-50161/[/url] I didn't want to use the OE upfitter switches for this as I have other plans for those. I decided to place the switch directly below the headlight and dimmer switch. Control wise it seems a logical place to operate them from. It was also a spot that didn't require any cutting or modification of the internal dash structure or bracing. Not the easiest to see as the lower panel slope away from you as you sit in the seat but the switch rocker is almost straight up and down when activated. I had the switches customized so the lower text portion is blue and connected to the dash light dimmer circuit. The upper LED is amber just like the factory switches and illuminates when on. I installed another switch (future project) and blanking plate in a three position switch holder that trims out the cut hole nicely. To wire the switches I replaced the crimped on female spades that came on the Starkey harness with an 8 terminal connector housing and the correct Packard terminals. I can now unplug them easily and never have to worry about the wiring order. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Gumby
SoCalRey
TCB
Raptor1776
24NoVARaptor
TheC-Don
tscarline
2slo4u
gjw535
hyrepower
J_OC_Raptor
iwish97
NoNeed
DigbyRaptor
EricM
Utexmed
RaptorAU
CleverGirl_
cwh
Old-Raptor-guy
PlainsRaptor
PGH_Raptor
fordfreek
Frofan
Highwayman
mike1307
SeasickLI
Sozzy12
downforce137
Gen2Boost
reesbridges
juniorg929
Zeusmotorworks
cazt51
Dave T
Basil S2K
WNCHSTR96
GCATX
aakbar_828
firemanjoe
chris51080
pirates1456
MurderedOutSVT
pr0sack
Northerndino
Punkur67
grleon65
Rcnfan3117
ToadSmasher2K1
... and 40 more.
93,333
56,622
pr0sack
Forums
Accept
Learn more…
