Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
Rear Block and Perch Adjustment
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Mluis11" data-source="post: 1002768" data-attributes="member: 17075"><p>I strongly suggest removing the leveling kit or you will cause damage over extended use at full droop. Do not go over mid perch or you will experience issues with your IWE's engaging and lose 4 wheel drive ultimately. As for the rear, I'd suggest new leaf springs to raise ride height. Deaver +3's will add 1" and +5's will give you 2"-2 1/2". </p><p></p><p>You can fit 37's for street driving with little to no trimming, but if you plan to do even moderate off-roading you'll need to hammer the pinch welds, cut your stock flares and fenders or purchase after market front fenders. </p><p></p><p>Level kits and blocks are no good if you want to retain function.</p></blockquote><p></p>
[QUOTE="Mluis11, post: 1002768, member: 17075"] I strongly suggest removing the leveling kit or you will cause damage over extended use at full droop. Do not go over mid perch or you will experience issues with your IWE's engaging and lose 4 wheel drive ultimately. As for the rear, I'd suggest new leaf springs to raise ride height. Deaver +3's will add 1" and +5's will give you 2"-2 1/2". You can fit 37's for street driving with little to no trimming, but if you plan to do even moderate off-roading you'll need to hammer the pinch welds, cut your stock flares and fenders or purchase after market front fenders. Level kits and blocks are no good if you want to retain function. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
oxford37
icecoldak
Romes86
Danny_Apolos
Dxtch
4wheelinAZ
jpl291
catinthehat85
sct
xlover
peeweeman250
hanj0208
cwh
ToadSmasher2K1
US HWY 666
Raptor_NV
mobiia
Coyote_695
WhiskeyTangoGTFO
hopkintj
Hal993
flyitaway
furioussphinx
FiestaJoe
Noplacelikeloam
im33303
AJ36_LeadFootG3
Hard R
johnnyutah
Peterb
Rucku5
93,240
56,529
osten100
Forums
Accept
Learn more…
