Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Exterior Modifications Forum [GEN 1]
Raptor bull bar
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Raptor Embroidery" data-source="post: 847025" data-attributes="member: 5177"><p>Hey buddy, here is my setup. You can order the defiant offroad light bar from their website but I had some modifications done. It has flat plate with 3 holes punched for looks welded between the radius bar and top hoop, then, it has flat bar welded between the radius bar and top hoop to hold 2 30" light bars.</p><p></p><p>Also added some tubular gusseting between the uprights and the radius bar to add rigidity and welded the bottom cross bar rather than bolting it up. </p><p></p><p>Lastly, I added flat bar on the mounts that come out from the tow hooks to make those more rigid as well. </p><p></p><p>I can stand up and jump on this light bar and there is not even a wiggle. </p><p></p><p>Also, the reason I went with this light bar is it is more of a fitting design for the Raptor. It's more of a baja bar rather than a bull bar.</p><p></p><p>Keep in mind these are old pictures and once the light bar was finished, it was coated in Line-x platinum</p><p></p><p>Stock Light bar with 4 8.7" vision-x lights</p><p>[ATTACH]61871[/ATTACH]</p><p></p><p>Welded, bare, with 2 30" led light bars mounted</p><p>[ATTACH]61872[/ATTACH]</p><p></p><p>On the truck (bare)</p><p>[ATTACH]61874[/ATTACH]</p><p></p><p>Complete</p><p>[ATTACH]61875[/ATTACH]</p></blockquote><p></p>
[QUOTE="Raptor Embroidery, post: 847025, member: 5177"] Hey buddy, here is my setup. You can order the defiant offroad light bar from their website but I had some modifications done. It has flat plate with 3 holes punched for looks welded between the radius bar and top hoop, then, it has flat bar welded between the radius bar and top hoop to hold 2 30" light bars. Also added some tubular gusseting between the uprights and the radius bar to add rigidity and welded the bottom cross bar rather than bolting it up. Lastly, I added flat bar on the mounts that come out from the tow hooks to make those more rigid as well. I can stand up and jump on this light bar and there is not even a wiggle. Also, the reason I went with this light bar is it is more of a fitting design for the Raptor. It's more of a baja bar rather than a bull bar. Keep in mind these are old pictures and once the light bar was finished, it was coated in Line-x platinum Stock Light bar with 4 8.7" vision-x lights [ATTACH]61871.vB[/ATTACH] Welded, bare, with 2 30" led light bars mounted [ATTACH]61872.vB[/ATTACH] On the truck (bare) [ATTACH]61874.vB[/ATTACH] Complete [ATTACH]61875.vB[/ATTACH] [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
RaptorVette
raptor618
Jay_P
RUFdriver
Bowlmsc
0341Marine
Zach Gen3
drj.raptor
HighwaySentinel
Hambone
rgoudsward
taquitos
Donovan
Gprapfan
Wartman
Rapdk
Morgan
HipHopHonky
flyitaway
Dan H
3Dog
BBLV
SeasickLI
PS08
BushwiickBill
DFS
elpechedepeche
kponenation
jwineco5
tm965
raptrrr
Zeke555
Latchkey Kid
CVF-Jason
RaptorAU
2slo4u
FordTechOne
raptorCAT06
MORaptor
Butterz
Drew59
20Ecoboost17
Shane361
RivRaptor
Derrick Hernandez
slater
Pacific Wheel
alibo70
Brent Lester
... and 27 more.
93,427
56,706
marquez47
Forums
Raptor bull bar
Accept
Learn more…
