Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Cleaning and Detailing Forum
Protect Your Rubber, Spare that is....
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="WRCRaptor" data-source="post: 937122" data-attributes="member: 10153"><p>I agree that dirt,sand,salt and water are contributing factors to this problem. Another thing I have noticed is that the tire moves around a bit on rougher roads it's not the most secure mount. One last issue is that as the air temp goes up and down the psi in the tire changes, so will the amount of pressure between the frame and tire. Colder = looser. </p><p></p><p>I think cutting some think plastic spacers will help with the rust issue but not likely the potential damage that the dirt/sand may cause. I guess it is possible that as the tire moves a little and psi goes down the spacers may fall out unless they are mounted to the frame somehow. </p><p></p><p>One thing I have done is I replaced a set of tires (G.Y. Duratrac) long before they were worn out so now I have half used spare I don't care so much about. I run that same tire on all three sets of non snow wheels so I now have good condition used spares for each set. </p><p></p><p>I also went a little crazy and bought a bunch of the OE beadlock wheels and have found a problem with the beauty/beadlock rings. Having that rim as a spare it is difficult to regularly wash during winter. The bolts face up and so salty water and in summer mud and sand are trapped there and cause issues. My answer is to use one of my original stk 2011 rims as a under bed spare for each set except my Methods.</p><p></p><p>Hi my name is W.G. and I have a wheel & tire addiction!! Hope that helps</p></blockquote><p></p>
[QUOTE="WRCRaptor, post: 937122, member: 10153"] I agree that dirt,sand,salt and water are contributing factors to this problem. Another thing I have noticed is that the tire moves around a bit on rougher roads it's not the most secure mount. One last issue is that as the air temp goes up and down the psi in the tire changes, so will the amount of pressure between the frame and tire. Colder = looser. I think cutting some think plastic spacers will help with the rust issue but not likely the potential damage that the dirt/sand may cause. I guess it is possible that as the tire moves a little and psi goes down the spacers may fall out unless they are mounted to the frame somehow. One thing I have done is I replaced a set of tires (G.Y. Duratrac) long before they were worn out so now I have half used spare I don't care so much about. I run that same tire on all three sets of non snow wheels so I now have good condition used spares for each set. I also went a little crazy and bought a bunch of the OE beadlock wheels and have found a problem with the beauty/beadlock rings. Having that rim as a spare it is difficult to regularly wash during winter. The bolts face up and so salty water and in summer mud and sand are trapped there and cause issues. My answer is to use one of my original stk 2011 rims as a under bed spare for each set except my Methods. Hi my name is W.G. and I have a wheel & tire addiction!! Hope that helps [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Hambone
KAJRIP
BBR
FreightTerrain
TheC-Don
Gumby
shayb16
Reaper_247
Frogger22
notwal
olverac
Fireman Dave
kactux
HAP
mattncsu
jAKe47
Admin.RealTruck
fordfreek
CleverGirl_
DDaddy99
Chewie
mike1307
NickyF25
RJackson
sparklinghat659
Sharpie69
mook5186
Russ103
Gdog
daytona1783
Seven Twenty
Psirus7
Raptor812
HOLLYWOOD 1
pat247
MFouts
WTX
DRC3
EagleFive
RaptorSS
awd5906
WRalstonB
cammac50
Jesse1983
GOTSVT?
Evasive
scg149
... and 2 more.
93,579
56,863
ShippRaptor
Forums
Accept
Learn more…
