Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford SVT Raptor General Discussions [GEN 1]
powerstroke in raptor?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="whoisbigman" data-source="post: 601054" data-attributes="member: 13259"><p>You might be able to get one in, probably would have to replumb some of the peripheral stuff, intercooler and turbo stuff... brake master cylinder, stuff that isnt necessarily rigidly attached to the motor. The tranny is bigger as is the t-case... 6-spped would be awesome. suspension would require a lot of work. Motor is heavier as is tranny. Anything can be done if you have enough money to throw at it. 7.3 would be way cooler than a 6.4 or 6.7.</p><p>A better idea might be a smaller diesel... Cummins 4BT would fit pretty easily... good for an easy 400 hp and better fuel mileage, and parts are cheaper. Less computer issues to deal with, also lighter. Suspension would work pretty well. if anything it would be taller in the engine bay but we have plenty of height in there.<span style="color: Red"></span></p><p><span style="color: Red"></span></p><p><span style="color: Red"><span style="font-size: 9px">---------- Post added at 11:46 AM ---------- Previous post was at 11:32 AM ----------</span></span></p><p><span style="color: Red"></span></p><p><span style="color: Red"></span>Great, thanks... now you have me thinking. I love diesels in unsuspecting retrofits, but why do you want to try this. Towing, pulling, rock climbing... not raptor stuff generally. that being said, frame would need beefing up, engine would sit more forward than in a Superduty so vehicle would be front end heavy, intercooler would require some thinking outside of the box. Stacks in the bed would be cool... through the hood even cooler.</p><p>Ecoboost would be cool. I would want more horsepower, could get expensive quick.</p><p>Research the Cummins 4BT solution if you just have to have a diesel. I bet you could find an entire map for putting one in an F-150 with the solution to every problem already figured out. Cost would be cheapest of all solutions.</p><p>I have a friend who put a 4BT in a Chevy 1500... 4-speed tranny, 500+hp with a single turbo and more torque than the law allows in a little pick-up.</p></blockquote><p></p>
[QUOTE="whoisbigman, post: 601054, member: 13259"] You might be able to get one in, probably would have to replumb some of the peripheral stuff, intercooler and turbo stuff... brake master cylinder, stuff that isnt necessarily rigidly attached to the motor. The tranny is bigger as is the t-case... 6-spped would be awesome. suspension would require a lot of work. Motor is heavier as is tranny. Anything can be done if you have enough money to throw at it. 7.3 would be way cooler than a 6.4 or 6.7. A better idea might be a smaller diesel... Cummins 4BT would fit pretty easily... good for an easy 400 hp and better fuel mileage, and parts are cheaper. Less computer issues to deal with, also lighter. Suspension would work pretty well. if anything it would be taller in the engine bay but we have plenty of height in there.[COLOR="Red"] [SIZE=1]---------- Post added at 11:46 AM ---------- Previous post was at 11:32 AM ----------[/SIZE] [/COLOR]Great, thanks... now you have me thinking. I love diesels in unsuspecting retrofits, but why do you want to try this. Towing, pulling, rock climbing... not raptor stuff generally. that being said, frame would need beefing up, engine would sit more forward than in a Superduty so vehicle would be front end heavy, intercooler would require some thinking outside of the box. Stacks in the bed would be cool... through the hood even cooler. Ecoboost would be cool. I would want more horsepower, could get expensive quick. Research the Cummins 4BT solution if you just have to have a diesel. I bet you could find an entire map for putting one in an F-150 with the solution to every problem already figured out. Cost would be cheapest of all solutions. I have a friend who put a 4BT in a Chevy 1500... 4-speed tranny, 500+hp with a single turbo and more torque than the law allows in a little pick-up. [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Big Blue
Administrator
Members online
Hambone
blazn5667
JohnyPython
wickeddose
horizon670
Rednose
NickyF25
drew5580
AJ36_LeadFootG3
pirates1456
Dan Ordoins
RaptorRobby
David1986
BBQness
Big Blue
Ski4Ever
nelsonr103
nixon
MarkOne
Billy Mc
93,240
56,530
osten100
Forums
Accept
Learn more…
