Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
Perch mod - with the shocks on the truck
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="The Brit" data-source="post: 211598" data-attributes="member: 2622"><p>I also did this mod today and was about to post my write up. I went about it in a similar way but wit a few tweaks. </p><p></p><p>I worked on one corner at a time, jacking the suspension arm directly, thus compressing the spring as much as possible and thus less time, effort and finagling with compressors. Less time cranking on spring compressors is a good thing in my mind. Placed the jack stand under the requisite frame rail and removed wheel. </p><p></p><p>At this point, I installed 4 spring compressors, 2 were the double prong type that are lower profile and fit on the inside, then 2 of the MacPherson compressors spaced where I could fit them on the outside. Tightened all 4 evenly. Clamped the spring to the spring hat and removed the sway bar nut and then lowered the suspension arm. </p><p></p><p>This gave me all the clearance to remove the set screw and move the perch assembly up to the middle setting and reinstall the set screw. Compressed air was good for blowing out the dust in the spring perch and other nooks and crannys.</p><p></p><p>I then moved the suspension arm back up with the jack to minimize the usage of the spring compressors and evenly loosened the spring compressors. Re-install the sway bar nut and the wheel...</p><p></p><p>Very happy with the results and suppose I'll try to get the truck in for an alignment on Monday.</p></blockquote><p></p>
[QUOTE="The Brit, post: 211598, member: 2622"] I also did this mod today and was about to post my write up. I went about it in a similar way but wit a few tweaks. I worked on one corner at a time, jacking the suspension arm directly, thus compressing the spring as much as possible and thus less time, effort and finagling with compressors. Less time cranking on spring compressors is a good thing in my mind. Placed the jack stand under the requisite frame rail and removed wheel. At this point, I installed 4 spring compressors, 2 were the double prong type that are lower profile and fit on the inside, then 2 of the MacPherson compressors spaced where I could fit them on the outside. Tightened all 4 evenly. Clamped the spring to the spring hat and removed the sway bar nut and then lowered the suspension arm. This gave me all the clearance to remove the set screw and move the perch assembly up to the middle setting and reinstall the set screw. Compressed air was good for blowing out the dust in the spring perch and other nooks and crannys. I then moved the suspension arm back up with the jack to minimize the usage of the spring compressors and evenly loosened the spring compressors. Re-install the sway bar nut and the wheel... Very happy with the results and suppose I'll try to get the truck in for an alignment on Monday. [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Griffin
Administrator
Members online
Ol_Blue
GCATX
Nyamg
Ryan C
acremer24
DMacDonald
Gen1Lucky13SVT
cuts
backfist
xgardx
AZRaptorR
37 Rapt NC
Howling_Coytote
mattncsu
Johnny149
Swifty
redracer64
ToadSmasher2K1
Inkd_firemedic
Finlay150
daddyd
Old-Raptor-guy
beemerb0y
Rey L
TK-421
DaveInMn
TheC-Don
FossilFuel
Griffin
nltruck
xturdfergusonx
termsheet
Donarash
Brewski
Braves Fan
Sozzy12
The Car Stereo Company
NickyF25
Hup
RaptorFan1988
HeyItsARaptor
Zeusmotorworks
iam_tylerbrown
stevenstommyboy1
mprice1234
Braaaaptor
Bubba0612
smgilles
Sparda1123
dfranks
... and 5 more.
93,574
56,862
Bwalt
Forums
Accept
Learn more…
