Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford F-150 Raptor General Discussions [GEN 2]
New Owner!
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="smurfslayer" data-source="post: 1206432" data-attributes="member: 21926"><p>pedal commander improves throttle response, especially with the truck in “normal” mode. it’s a little box that plugs in between the throttle connectors, altering the signal sent to the throttle. Stock, the Raptor in normal mode drives around with the throttle response best described as slow. The Truck’s sport mode improves this and keeps Rpms above about 1900. Pedal commander can make normal mode tolerable, but it still jumps into 10th by 40mph. If your long term plans include a tune, boostmax or similar, a pedal commander is probably not money well spent as you’ll end up replacing it. </p><p>But, if you’re staying stock or close to it, P/C will dramatically improve throttle response. We have several FRF Supporting Vendors who sell them.</p><p></p><p>I have thread in the g2 audio subform ‘added a sub’ illustrating how to do the sub, box etc for the Sony system. Not sure if the B&O is significantly different. I used the Kicker 8” sub, good for 300w mono, [MENTION=22717]Guy[/MENTION] did a pioneer 8” sub at I think 250 w. I also had great results wrapping the sub enclosure in dynamat.</p></blockquote><p></p>
[QUOTE="smurfslayer, post: 1206432, member: 21926"] pedal commander improves throttle response, especially with the truck in “normal” mode. it’s a little box that plugs in between the throttle connectors, altering the signal sent to the throttle. Stock, the Raptor in normal mode drives around with the throttle response best described as slow. The Truck’s sport mode improves this and keeps Rpms above about 1900. Pedal commander can make normal mode tolerable, but it still jumps into 10th by 40mph. If your long term plans include a tune, boostmax or similar, a pedal commander is probably not money well spent as you’ll end up replacing it. But, if you’re staying stock or close to it, P/C will dramatically improve throttle response. We have several FRF Supporting Vendors who sell them. I have thread in the g2 audio subform ‘added a sub’ illustrating how to do the sub, box etc for the Sony system. Not sure if the B&O is significantly different. I used the Kicker 8” sub, good for 300w mono, [MENTION=22717]Guy[/MENTION] did a pioneer 8” sub at I think 250 w. I also had great results wrapping the sub enclosure in dynamat. [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Big Blue
Administrator
Members online
shigman
Big Blue
Sever18
IIAWAH808
TomDirt
kirkb
tm965
JESTX5
Falcon64
Reptar854
RRick
pat247
Gatica
jdm_sixtwo
Diablo
BigBlue20
Oldfart
houtex1
Nohowtoplz
Gorzz
Chzhead
BenBB
ToadSmasher2K1
Hagdio72
Raptor801
njhummer18
Raptorman19
hingedthinker
Muchmore
Arizona Free
tcm glx
B boyes
Kronos2300
Syberspace
Bubba0612
isldtime
kandewinn
cjhoneyman
levileb91
Ol_Blue
HuffRanch
GaoKS
Tbogo
mleaky
CoolrainRaptor
MurderedOutSVT
Rekkr
-RRRaptor-
sfckelley
bdherh
... and 24 more.
93,302
56,593
sdavis007
Forums
New Owner!
Accept
Learn more…
