Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Wheels & Tires Forum [GEN 1]
modifying method center caps
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="khcdave" data-source="post: 265057" data-attributes="member: 2570"><p>I wasnt happy with how my method standard center caps stuck out so I decided to shorten them. It was pretty easy. Used 1 1/2in tape, tin snips and small channel lock pliers.[ATTACH]11454[/ATTACH] Taped them up and cut along the line [ATTACH]11455[/ATTACH] bent a new lip along with 3 stick outs that hold them tight when the wheel is installed. [ATTACH]11459[/ATTACH][ATTACH]11456[/ATTACH][ATTACH]11457[/ATTACH] Took about and hour to do all 4 and I like the look much better- not my preference to run no caps at all so this was my alternative.</p></blockquote><p></p>
[QUOTE="khcdave, post: 265057, member: 2570"] I wasnt happy with how my method standard center caps stuck out so I decided to shorten them. It was pretty easy. Used 1 1/2in tape, tin snips and small channel lock pliers.[ATTACH]11454.vB[/ATTACH] Taped them up and cut along the line [ATTACH]11455.vB[/ATTACH] bent a new lip along with 3 stick outs that hold them tight when the wheel is installed. [ATTACH]11459.vB[/ATTACH][ATTACH]11456.vB[/ATTACH][ATTACH]11457.vB[/ATTACH] Took about and hour to do all 4 and I like the look much better- not my preference to run no caps at all so this was my alternative. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
swreptar
MattC1996
Raptus
encyphered
BoostCreep
SunRaptor
berto2323
stevelp99
ausmark
icecoldak
Morrisabm
MuscleHamster89
Beinkounter
kocher93
xlover
chris426
VJDWashington
hemibob
KMO
taquitos
joeyrotorhead
n00dler
tcm glx
Domin0
RaptorReptar01
93,277
56,567
erikn
Forums
Accept
Learn more…
