Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Lighting Modifications Forum [GEN 1]
Light setup question
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ajstar89" data-source="post: 909550" data-attributes="member: 10558"><p>Hey guys,</p><p>I'am getting ready to install my bed light setup. I was wondering if you guys could give me a double check before I start to build the wiring harness. I am also installing a power actuator. I am planning on wiring it described below any comments would be greatly appreciated.</p><p></p><p></p><p>10 gauge positive ran straight from battery to bed, with fuse installed </p><p></p><p>six 20 watt gravity lights wired in parallel with 14 or 16 gauge wire. Wire will be attached to a fuse then to the relay. Relay will be wire with 12 volt form battery, and up fitter for 87a switch and grounded to the frame</p><p></p><p>two 20 watt cubes wired in parallel with 16 gauge wire. Wire will be attached to a fuse and then a relay. Relay will be wire with 12 volt form battery, and up fitter for 87a switch and grounded to the frame </p><p></p><p>actuator power will be used from 12v direct to bed with a fuse. Hooked into relay similar to above using a custom switch in the cab.</p><p></p><p>I believe this is the most efficient and safest way to wire the setup in the bed. Any thoughts and comments about it are greatly appreciated. </p><p></p><p>Cheers!</p></blockquote><p></p>
[QUOTE="ajstar89, post: 909550, member: 10558"] Hey guys, I'am getting ready to install my bed light setup. I was wondering if you guys could give me a double check before I start to build the wiring harness. I am also installing a power actuator. I am planning on wiring it described below any comments would be greatly appreciated. 10 gauge positive ran straight from battery to bed, with fuse installed six 20 watt gravity lights wired in parallel with 14 or 16 gauge wire. Wire will be attached to a fuse then to the relay. Relay will be wire with 12 volt form battery, and up fitter for 87a switch and grounded to the frame two 20 watt cubes wired in parallel with 16 gauge wire. Wire will be attached to a fuse and then a relay. Relay will be wire with 12 volt form battery, and up fitter for 87a switch and grounded to the frame actuator power will be used from 12v direct to bed with a fuse. Hooked into relay similar to above using a custom switch in the cab. I believe this is the most efficient and safest way to wire the setup in the bed. Any thoughts and comments about it are greatly appreciated. Cheers! [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
blueherron96
Reptar854
uncboysetsfire
Hambone
Raptor_NV
WatFam
oswiff
Chewie
Frogger22
MDJAK
AfterMidnightRambler
RaptorJamo
Winchester30
butts182
bounsmith21
scroper
IIAWAH808
Pacifico66
Harry P Ness
isis
BT-Phx
77Raptor
SSWIM
NoSleeper
Venti Raptor
Trail_Rider
tractorpole
Skyfrog
james9
Jdselig
EricM
MajorAR
wheelson
Mike27t
tm965
doktor
Morgan
bakwaas4eva
dvm
DTZ
Crywolf4
aakbar_828
julien194b
Sharpie69
samwelll
FordPerf Addict
2024RaptorR_NOVA
IHAVETWO
quattrojim
... and 1 more.
93,241
56,530
osten100
Forums
Accept
Learn more…
