Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Interior Modifications Forum [GEN 1]
LED Footwell lighting
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Harblar" data-source="post: 572891" data-attributes="member: 8673"><p>Found the right wire. Was pin 6, though it looks yellow with a green stripe to me... Oh well. Thanks for the help. I could've spent a week trying to find that one! <img src="/styles/default/xenforo/smilies/rockit.gif" class="smilie" loading="lazy" alt=":rockit:" title="Rockit :rockit:" data-shortname=":rockit:" /></p><p></p><p>Also discovered that the led controller/driver I was using was defective. Switched to a different one I had and it works nearly perfect.... Only problem it has is lack of a memory, meaning that every time the power cycles, on/off/on, the lights reset to a slow blink state where it randomly switches colors every two seconds or so. That's not gonna work. Any controller recommendations that'll remember and default to the last used setting?</p><p></p><p>I'm just using the standard four wire RGB led strips you can get off from Amazon and only need to power 2-3 feet of lights.</p></blockquote><p></p>
[QUOTE="Harblar, post: 572891, member: 8673"] Found the right wire. Was pin 6, though it looks yellow with a green stripe to me... Oh well. Thanks for the help. I could've spent a week trying to find that one! :rockit: Also discovered that the led controller/driver I was using was defective. Switched to a different one I had and it works nearly perfect.... Only problem it has is lack of a memory, meaning that every time the power cycles, on/off/on, the lights reset to a slow blink state where it randomly switches colors every two seconds or so. That's not gonna work. Any controller recommendations that'll remember and default to the last used setting? I'm just using the standard four wire RGB led strips you can get off from Amazon and only need to power 2-3 feet of lights. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
kirkb
Booth9999
pirates1456
DaveInMn
Beinkounter
RivRaptor
shoracer
DMNHNTR
New recaros
DFWRob
GreenGoblin
alockbox
hudidad
Pismobound
green7
cfabrizio
Neckface
Hard R
Johnny149
dleclerc27
raptrrr
briangsxr1000
SeasickLI
qbonmike
Gumby
WH7
catinthehat85
HuffRanch
Rigged_Up_Raptor
Hambone
Sharpie69
Robertcrav
Airmanrdb
Howling_Coytote
rp2024
MattyIce716
Keith88
GCATX
Zeke555
Sozzy12
bayley_dl
Hotrod-Realtor
Domin0
Chewie
S1ackin
IIAWAH808
OICNW-Rob
DLaw0522
tcm glx
mprice1234
... and 34 more.
93,434
56,717
Poseidon02
Forums
Accept
Learn more…
