Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Engine Discussion and Performance Mods
Kooks DP, AFE intake, tubo adapters, SP 542 plugs and coolant temp question
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Onemoosehorn" data-source="post: 1278695" data-attributes="member: 27264"><p>Not tuned. No extra boost. Just the intake, DP, adapters and 542’s gapped at .028. I swapped out the original plugs last night and drove around to see if that affected the coolant temp. It did not. So I put the 542’s back in. This morning I threw the misfire warning. Have not had a chance to get the code read yet. Maybe I’ll close them to .025 to see if it stops the misfire. I’m getting the code read after work.</p><p></p><p>71 degrees this morning and the truck still ran warmer. Hit 221 at one time. But it quickly drops back to 202-205 off the boost. Hell even under 200 downhill. Averaged 210-212 degrees.</p></blockquote><p></p>
[QUOTE="Onemoosehorn, post: 1278695, member: 27264"] Not tuned. No extra boost. Just the intake, DP, adapters and 542’s gapped at .028. I swapped out the original plugs last night and drove around to see if that affected the coolant temp. It did not. So I put the 542’s back in. This morning I threw the misfire warning. Have not had a chance to get the code read yet. Maybe I’ll close them to .025 to see if it stops the misfire. I’m getting the code read after work. 71 degrees this morning and the truck still ran warmer. Hit 221 at one time. But it quickly drops back to 202-205 off the boost. Hell even under 200 downhill. Averaged 210-212 degrees. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Raptor812
BBR
kirkb
schumacher1111
mprice1234
RaptorFun
VFLRads
wyomingraptor
Latchkey Kid
dfw62
Sharpie69
RCorsa
blazn5667
oliver1539
jond
GOTX
Irregular F150
Zeusmotorworks
jfondren3
Gotdesl
Reptar854
GaoKS
RaptorJoe331
Chop96
ScottS23
LayinWatts69
never_summer
jdm_sixtwo
stevenstommyboy1
IHAVETWO
Frogger22
NickyF25
MurderedOutSVT
Speedhunter
ToadSmasher2K1
Josfue
CleverGirl_
Hambone
jackrabbitt1
Jmeo
shank_guru
riv
CVP33
ausmark
whatthetruck
Nood1es
Shane361
pastorwug
rfranklin1
DMacDonald
... and 16 more.
93,191
56,469
ngodavid23
Forums
Accept
Learn more…
