Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forum Supporting Vendors
Vendor Feedback
KHC Awesome guys!
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="FullAuto" data-source="post: 669612" data-attributes="member: 12678"><p>Positive for KHC. I scheduled an appointment here just to swap out a new set of Method Mesh (that I ordered through another vendor) with my current stock rims. I figured it would give me a chance to check out the shop for future mods. Well they went above and beyond for me yesterday. After the tires were mounted they noticed one wheel was not the correct bolt pattern. I had checked all the box labels when they first came in and opened each box but didn’t catch the miss labeled rim. So they first called the vendor and left a message about the miss-labeled rim (not their fault either as it came this way from Method). Then they called a few local Method vendors to try and get me a correct rim. After they had no luck with that they offered to mount up a Method Standard that came off their shop truck for me to borrow till my rim comes in. I was able to drive my 1.5 hour ride home and make it to work on time that afternoon. They honestly had no idea I had to be at work they just jumped right in and did all this on their own. Looks like I found the shop I want to install my future mods. Thanks KHC!</p></blockquote><p></p>
[QUOTE="FullAuto, post: 669612, member: 12678"] Positive for KHC. I scheduled an appointment here just to swap out a new set of Method Mesh (that I ordered through another vendor) with my current stock rims. I figured it would give me a chance to check out the shop for future mods. Well they went above and beyond for me yesterday. After the tires were mounted they noticed one wheel was not the correct bolt pattern. I had checked all the box labels when they first came in and opened each box but didn’t catch the miss labeled rim. So they first called the vendor and left a message about the miss-labeled rim (not their fault either as it came this way from Method). Then they called a few local Method vendors to try and get me a correct rim. After they had no luck with that they offered to mount up a Method Standard that came off their shop truck for me to borrow till my rim comes in. I was able to drive my 1.5 hour ride home and make it to work on time that afternoon. They honestly had no idea I had to be at work they just jumped right in and did all this on their own. Looks like I found the shop I want to install my future mods. Thanks KHC! [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
David1986
Havok_RLS2
GreenGoblin
loganl86
BahaBlastediam
ImjustSteven
nelsonr103
WH7
lakebum
93,190
56,469
ngodavid23
Forums
Vendor Feedback
KHC Awesome guys!
Accept
Learn more…
