Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford F-150 Raptor General Discussions [GEN 2]
key fob programming
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="David Nelson" data-source="post: 1778130" data-attributes="member: 42543"><p>Only if you use the key to start and do not have a start button. "</p><p>These Ford key fob programming instructions are all you need to ensure that keyless entry is functioning as it should!</p><p></p><ol> <li data-xf-list-type="ol">Make sure all car doors are closed. Enter the car via the driver-side door, pressing the UNLOCK button inside the doorframe.</li> <li data-xf-list-type="ol">In a 10-second span, turn the key in the ignition from OFF to RUN eight times. The last turn should leave the car on RUN.</li> <li data-xf-list-type="ol">At this point, you should have entered programming mode, indicated by the door locks cycling between lock and unlock. If they do not, repeat step 2, turning the key faster.</li> <li data-xf-list-type="ol">Once in programming mode, press any button on your Ford remote. This must be completed within eight seconds of the door locks beginning to cycle. They will cycle again to confirm your remote has been programmed and is now ready to use.</li> <li data-xf-list-type="ol">Repeat step 4 for additional remote key fobs, as needed.</li> <li data-xf-list-type="ol">When finished, turn the ignition to OFF. Your door locks may cycle again as another confirmation of programming completion."</li> </ol><p>Almost the very same thing on my 2000 GMC.</p></blockquote><p></p>
[QUOTE="David Nelson, post: 1778130, member: 42543"] Only if you use the key to start and do not have a start button. " These Ford key fob programming instructions are all you need to ensure that keyless entry is functioning as it should! [LIST=1] [*]Make sure all car doors are closed. Enter the car via the driver-side door, pressing the UNLOCK button inside the doorframe. [*]In a 10-second span, turn the key in the ignition from OFF to RUN eight times. The last turn should leave the car on RUN. [*]At this point, you should have entered programming mode, indicated by the door locks cycling between lock and unlock. If they do not, repeat step 2, turning the key faster. [*]Once in programming mode, press any button on your Ford remote. This must be completed within eight seconds of the door locks beginning to cycle. They will cycle again to confirm your remote has been programmed and is now ready to use. [*]Repeat step 4 for additional remote key fobs, as needed. [*]When finished, turn the ignition to OFF. Your door locks may cycle again as another confirmation of programming completion." [/LIST] Almost the very same thing on my 2000 GMC. [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Griffin
Administrator
Members online
23f150
MurderedOutSVT
dsg2003mach1
trailerjack
elpechedepeche
Bozz
Johnny149
Madhouse
ToadSmasher2K1
taquitos
XSTNKT
-RRRaptor-
Morgan
northlaker
shigman
H20guy310
roger7254
Dano182
nolantx05
Spydie35
BoostCreep
Neens
JacketedHP
ScottS23
Domin0
flyitaway
JohnyPython
22R37
never_summer
QCRappy
04Ram2500Hemi
Latchkey Kid
hamster
EastEndAngler
JD05
DS550
Griffin
kandewinn
tcm glx
FmaxTurboSi
TwizzleStix
Singhraptor
RaptorAU
Raptor Rob
Jhollowell
utahraptor801
kocher93
greatone99
joeyrotorhead
NJ2020
... and 36 more.
93,255
56,552
iAmNotorious
Forums
key fob programming
Accept
Learn more…
