Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford F-150 Raptor General Discussions [GEN 2]
Is 38 psi for mpg only!
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="AZEngineer" data-source="post: 1201472" data-attributes="member: 8282"><p>Find a smooth piece of pavement and put white paper on the ground and drive over it. The contact patch of the tire will imprint on the paper. Trial and error will find the pressure that is just low enough to print the entire width of the tread. Higher and you get less patch, and lower the tire will generate more heat when running. With most cars I've found the factory pressure too high. With our BMWs it's been spot on, which makes sense as they are designed for high speed performance driving.</p></blockquote><p></p>
[QUOTE="AZEngineer, post: 1201472, member: 8282"] Find a smooth piece of pavement and put white paper on the ground and drive over it. The contact patch of the tire will imprint on the paper. Trial and error will find the pressure that is just low enough to print the entire width of the tread. Higher and you get less patch, and lower the tire will generate more heat when running. With most cars I've found the factory pressure too high. With our BMWs it's been spot on, which makes sense as they are designed for high speed performance driving. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
riv
Lifted&slifted
Johnny Raptor
pirates1456
Evil Peaches
Reptar854
Duane R
B00ST
mwaite09
DFS
Zach Gen3
Dudebrodude
alex323
Ronin4130
samwelll
FJohnny
taquitos
jrotelle
Hambone
tonyg969
Telecaster480
Spike Spiegel
HighwaySentinel
EricM
brink
Shane361
Karter01
Singhraptor
BBQness
77Raptor
ss55539
nighttrain777
k3k0a808
ToadSmasher2K1
Tbutkus
A305Raptor
Irregular F150
RaptorJoe331
basstheman
elpechedepeche
BadWRP
Wichadicha
RHCLLC
Speedhunter
JayB
LANRAPTOR
st33zygill
Powerlies
Frogger22
... and 36 more.
93,252
56,546
jrotelle
Forums
Accept
Learn more…
