Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Lighting Modifications Forum [GEN 1]
Ideal light setup suggestions
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Nick@Apollo-Optics" data-source="post: 752425" data-attributes="member: 1314"><p>My personal setup is a 40" Elite combo pattern in the upper grille below the FORD and a 30" Elite spot pattern in the upper grille above the FORD. I then have 2 Apollo4 spots in the lower inside fog openings and 2 Apollo4 amber floods on the outside fog openings. I also have 2 Apollo4 floods mounted in the rear as auxiliary lighting. I plan to also add some hood mounts as well. I don't have the 20" in the lower grille because I run a front plate since they're required in Texas. Although I have considered adding a couple 4" Elite floods in that location adjacent to the plate. </p><p></p><p>Hope this helps you make your decision, if you have any other questions, just let me know!</p></blockquote><p></p>
[QUOTE="Nick@Apollo-Optics, post: 752425, member: 1314"] My personal setup is a 40" Elite combo pattern in the upper grille below the FORD and a 30" Elite spot pattern in the upper grille above the FORD. I then have 2 Apollo4 spots in the lower inside fog openings and 2 Apollo4 amber floods on the outside fog openings. I also have 2 Apollo4 floods mounted in the rear as auxiliary lighting. I plan to also add some hood mounts as well. I don't have the 20" in the lower grille because I run a front plate since they're required in Texas. Although I have considered adding a couple 4" Elite floods in that location adjacent to the plate. Hope this helps you make your decision, if you have any other questions, just let me know! [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Griffin
Administrator
Members online
jwkhd1
rfranklin1
Westbayou
Neddy
james9
Frogger22
k3k0a808
jimmyjamm
Simon001
jAKe47
So-Cal-Al-52
Beinkounter
New recaros
LibertyDNP
Spike Spiegel
schumacher1111
shigman
jstnumber73
Reaper308
amazin
sobiloff
levileb91
DFS
GCATX
Punkur67
Irregular F150
Griffin
nelsonr103
nikhsub1
Morgan
ToadSmasher2K1
Mikemd
Nantucketdink
lawtonmc
A305Raptor
bcc
elpechedepeche
RaptorFan1988
BadWRP
piracy
bigjava2002
Pacifico66
IHAVETWO
kevo_lo
raptorCAT06
kevanscpa
bspeed78
JD05
GLT
Latchkey Kid
... and 46 more.
93,298
56,586
levileb91
Forums
Accept
Learn more…
