Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Suspension Discussion and Modification
Icon AAC leveling kit installed
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="TXRaptor" data-source="post: 1279228" data-attributes="member: 181"><p>Take a quick look at the ICON adjustable collar online and you will see it has an upper and lower component. The upper component is not used for the 1.0 and 1.75, so those two settings are "easier" to install.</p><p></p><p>While the RPG adjustable collar can be removed and adjusted, it will become more difficult to adjust with time due to dirt and corrosion in the threads. Most people choose the RPG static models because they know how high they want to go. If you are unsure, you will pay more for the adjustable version, and you will have to go through the whole installation process again to adjust them. (ie. Compress the springs, etc.)</p><p></p><p>If you are planning to go with 37s, I recommend the Geiser progressive springs over any of the perch collar options. Since you live in the Houston area, give Shaun Miller a call at Miller Off Road Design or message him on Facebook for installation services. He can discuss the various options and give you his recommendation based on what you want to achieve.</p></blockquote><p></p>
[QUOTE="TXRaptor, post: 1279228, member: 181"] Take a quick look at the ICON adjustable collar online and you will see it has an upper and lower component. The upper component is not used for the 1.0 and 1.75, so those two settings are "easier" to install. While the RPG adjustable collar can be removed and adjusted, it will become more difficult to adjust with time due to dirt and corrosion in the threads. Most people choose the RPG static models because they know how high they want to go. If you are unsure, you will pay more for the adjustable version, and you will have to go through the whole installation process again to adjust them. (ie. Compress the springs, etc.) If you are planning to go with 37s, I recommend the Geiser progressive springs over any of the perch collar options. Since you live in the Houston area, give Shaun Miller a call at Miller Off Road Design or message him on Facebook for installation services. He can discuss the various options and give you his recommendation based on what you want to achieve. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
relak
Eisner62
Reptar854
AZ Raptor
Judd McPherson
Dan H
sh00k
Sharpie69
kylesatx
Pikser
Shane361
1BAD454SSv2
ToadSmasher2K1
loganl86
XSTNKT
MarkOne
east raptor 22
SSWIM
Traderjab1
CoolrainRaptor
sambhutta
RaystownRaptor
IHAVETWO
04Ram2500Hemi
raptrrr
dvm
jekyll537
03Cobraraptor
SeasickLI
jdm_sixtwo
ausmark
isis
hamster
MZRaptor72
mgbond12
93,203
56,485
bjorn-dpc
Forums
Accept
Learn more…
