Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forum Supporting Vendors
CARiD.com
How to install projector headlights with LED or Halo rings?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="carid" data-source="post: 862392" data-attributes="member: 15359"><p>[ATTACH=full]245016[/ATTACH]</p><p></p><p>There is a great selection of complete replacement headlights with custom design for Ford F150 models. Those headlights are usually equipped with all needed bulbs and wiring, and some of them come with additional LEDs, halo rings and U-bar style daytime running lights.</p><p></p><p>Today we would like to share with you the YouTube video installation instructions and recommendation on how to change headlights on your truck:</p><p></p><p><strong>1. How to install headlights, connect High/low beams and turn signal.</strong></p><p><a href="https://www.youtube.com/watch?v=9EjBnF73UM4" target="_blank">https://www.youtube.com/watch?v=9EjBnF73UM4</a></p><p></p><p><strong>2. How to I connect the LEDs, halo rings or U-bar DRLs</strong></p><p><a href="https://www.youtube.com/watch?v=eOHioaJp-Vk" target="_blank">https://www.youtube.com/watch?v=eOHioaJp-Vk</a></p><p></p><p><strong>Check the full list of aftermarket headlights for FORD F150 on the following page:</strong></p><p><a href="http://www.carid.com/ford-f-150-headlights/" target="_blank">Ford F-150 Aftermarket Headlights</a></p><p></p><p></p><p>Most of aftermarket headlights are designed for F150 Trucks equipped with stock halogen headlights.</p><p>However some headlights for late model F150 have special versions for trucks with stock HID headlights. In such cases you may see the following sub model selector:</p><p></p><p>[ATTACH=full]245017[/ATTACH]</p><p></p><p>It is very important to chose the right option for your truck as the headlights have different inner part to match your specific light system. </p><p></p><p><strong>My F150 was equipped with stock HID (xenon headlights)</strong></p><p></p><p>The light system in such trucks is different and a little bit more complex. HID unit has different bulbs, wiring and ballasts.</p><p>Factory HID lights provide very good brightness and light intensity. Aftermarket headlights allow you to keep your stock HID unit and reuse it in the new headlights.</p><p>Aftermarket headlights for HID models come without bulbs and wiring and designed to accommodate your stock HID system.</p><p>This way you receive good looking headlights and keep the original bright HID light.</p><p></p><p><strong>My F150 has regular stock halogen headlights.</strong></p><p></p><p>In this case you will receive a complete replacement headlight equipped with all bulbs and wiring, so all you would have to do is just to replace them.</p><p>High beam, low beam and turn signal connectors are plug-and-play.</p><p></p><p>[ATTACH=full]245018[/ATTACH]</p></blockquote><p></p>
[QUOTE="carid, post: 862392, member: 15359"] [ATTACH=full]245016[/ATTACH] There is a great selection of complete replacement headlights with custom design for Ford F150 models. Those headlights are usually equipped with all needed bulbs and wiring, and some of them come with additional LEDs, halo rings and U-bar style daytime running lights. Today we would like to share with you the YouTube video installation instructions and recommendation on how to change headlights on your truck: [B]1. How to install headlights, connect High/low beams and turn signal.[/B] [url]https://www.youtube.com/watch?v=9EjBnF73UM4[/url] [B]2. How to I connect the LEDs, halo rings or U-bar DRLs[/B] [url]https://www.youtube.com/watch?v=eOHioaJp-Vk[/url] [B]Check the full list of aftermarket headlights for FORD F150 on the following page:[/B] [url=http://www.carid.com/ford-f-150-headlights/]Ford F-150 Aftermarket Headlights[/url] Most of aftermarket headlights are designed for F150 Trucks equipped with stock halogen headlights. However some headlights for late model F150 have special versions for trucks with stock HID headlights. In such cases you may see the following sub model selector: [ATTACH=full]245017[/ATTACH] It is very important to chose the right option for your truck as the headlights have different inner part to match your specific light system. [B]My F150 was equipped with stock HID (xenon headlights)[/B] The light system in such trucks is different and a little bit more complex. HID unit has different bulbs, wiring and ballasts. Factory HID lights provide very good brightness and light intensity. Aftermarket headlights allow you to keep your stock HID unit and reuse it in the new headlights. Aftermarket headlights for HID models come without bulbs and wiring and designed to accommodate your stock HID system. This way you receive good looking headlights and keep the original bright HID light. [B]My F150 has regular stock halogen headlights.[/B] In this case you will receive a complete replacement headlight equipped with all bulbs and wiring, so all you would have to do is just to replace them. High beam, low beam and turn signal connectors are plug-and-play. [ATTACH=full]245018[/ATTACH] [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Griffin
Administrator
Members online
NickyF25
riv
JohnyPython
Griffin
06z
Haydel53
albertgon1
kandewinn
Solboricua18
Littlefx4
jAKe47
navy2x
nemx735
Gdog
cb35
debauch
jekyll537
alockbox
Hard R
GreenGoblin
Northerndino
kocher93
Dudebrodude
xlover
Stingray23
Telecaster480
IIAWAH808
ToadSmasher2K1
TX-RAP70R
jm77
Raptor Harris
HeyItsARaptor
Gator85
US HWY 666
MSP
HORN HIGH ACES
JBTAC
oxford37
bjorn-dpc
SuprSeb
OrangemanOtto
03Cobraraptor
LayinWatts69
jdm_sixtwo
Nantucketdink
sh00k
CVP33
REX111
Raptorrunner
Eisner62
... and 21 more.
93,197
56,485
bjorn-dpc
Forums
CARiD.com
Accept
Learn more…
