Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Exhaust and Cutouts Discussion [GEN 1]
How should I attach a cat back exhaust?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="chartquist" data-source="post: 892120" data-attributes="member: 15878"><p>Looking for advice... there are tons of threads here on which cat back exhaust is best, but I haven't seen much on the best way to attach the new exhaust to the pipe from the cat. I plan to delete the resonator. Is it best to just line them up dry and tighten the bolts down? Should I put in an exhaust gasket or use Copper RTV on the joint? Should I use red Loctite on the bolts? Finally, how much should I tighten the bolts? I want to avoid any leaks at that joint and I sure don't want the bolts to come out. Also want to make sure they can be removed if I ever want to switch back to the stock exhaust for resale, etc. Thanks.</p></blockquote><p></p>
[QUOTE="chartquist, post: 892120, member: 15878"] Looking for advice... there are tons of threads here on which cat back exhaust is best, but I haven't seen much on the best way to attach the new exhaust to the pipe from the cat. I plan to delete the resonator. Is it best to just line them up dry and tighten the bolts down? Should I put in an exhaust gasket or use Copper RTV on the joint? Should I use red Loctite on the bolts? Finally, how much should I tighten the bolts? I want to avoid any leaks at that joint and I sure don't want the bolts to come out. Also want to make sure they can be removed if I ever want to switch back to the stock exhaust for resale, etc. Thanks. [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Griffin
Administrator
Members online
jm77
Cronn99
2slo4u
Griffin
redsmoke
RedlineHD
swreptar
mike Hamel
hdvvraptor
wyomingraptor
yoxxi
green7
oliverb
Frogger22
encyphered
trailerjack
tst
elpechedepeche
ToadSmasher2K1
VJDWashington
LambSVT
Telecaster480
XtraSpclCrspy
Morgan
icecoldak
oRoarke
petrolhead
kevo_lo
ljn21
RaptorMach3p5
IvyFire40
jsouth5
taquitos
Zach M
m0sdef
93,273
56,557
oRoarke
Forums
Accept
Learn more…
