Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Lighting Forum [GEN 2]
Help! No power on Upfitter 1 and 2, fuses are good
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="MAMiller44" data-source="post: 1612616" data-attributes="member: 40761"><p>Sounds like you're doing everything right. Last thing I would recommend is check the pass-thru wiring bundle, maybe something was modified at one point in time and those Aux 1/2 wires are the hot ones for some reason? You never know what happened with a previous owner. I guess if I were you I'd try to see what Ford says taking a look at it.</p><p></p><p>Worst case? Get the fuse box like you saw in my thread, and pull your own new wires directly to the battery/fuses/Aux 1+2 switches. One benefit to that is that you can upsize the wire gauge for 20a fuses and run two LP's off each.</p></blockquote><p></p>
[QUOTE="MAMiller44, post: 1612616, member: 40761"] Sounds like you're doing everything right. Last thing I would recommend is check the pass-thru wiring bundle, maybe something was modified at one point in time and those Aux 1/2 wires are the hot ones for some reason? You never know what happened with a previous owner. I guess if I were you I'd try to see what Ford says taking a look at it. Worst case? Get the fuse box like you saw in my thread, and pull your own new wires directly to the battery/fuses/Aux 1+2 switches. One benefit to that is that you can upsize the wire gauge for 20a fuses and run two LP's off each. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
RaptorFan1988
twoputtbirdie
carlos0001025
TAC71
rp2024
Doubleeaz
upstv
kevo_lo
dsg2003mach1
Whoops
redsmoke
dnewman9
GLT
Reptar25
Sage
IamNomad
iam_tylerbrown
Herrlich
KMO
Mtaylor760
Deejay
vudu_raptor
rma
kactux
flyitaway
Zeusmotorworks
bobbyph1
BoostCreep
Seven Twenty
shelteredraptor
MACSTX300
Pnwrider
The Car Stereo Company
93,637
56,943
reinharm1959
Forums
Accept
Learn more…
