Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
Has anyone cut the inside of their front fender wells ? Could use some help
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="DEADEYE" data-source="post: 131902" data-attributes="member: 1390"><p>I am running middle perch , Pro comp 9047-7936, Goodyear MTR's with Kevlar. I am still getting some rub on the inboard side of each front fender well . This is do to the rim back spacing and off set being different then stock. It only happens when suspension is working a little and I am almost at full turn . It does not rub that much or that often , however it will be enough to rip the fender flares off if I do this at speed . When I went to middle perch my alignment adjustments are maxed out on one of the adjustment points , and I do not want to get a San Diego rake going . I like it the way it is . This leaves me one choice or limited choices. I am considering cutting the inboard fender wells and could use some help if anyone has some advice . Or was wondering if anyone has done this . I searched the site and could not come up with anything. Any help would be appreciated.</p></blockquote><p></p>
[QUOTE="DEADEYE, post: 131902, member: 1390"] I am running middle perch , Pro comp 9047-7936, Goodyear MTR's with Kevlar. I am still getting some rub on the inboard side of each front fender well . This is do to the rim back spacing and off set being different then stock. It only happens when suspension is working a little and I am almost at full turn . It does not rub that much or that often , however it will be enough to rip the fender flares off if I do this at speed . When I went to middle perch my alignment adjustments are maxed out on one of the adjustment points , and I do not want to get a San Diego rake going . I like it the way it is . This leaves me one choice or limited choices. I am considering cutting the inboard fender wells and could use some help if anyone has some advice . Or was wondering if anyone has done this . I searched the site and could not come up with anything. Any help would be appreciated. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
trav7314
visionxp
Digipax
tonythis
flyitaway
stevelp99
pander952
RNA352
elpechedepeche
halemeister
MrSasquatch
zachery55
luism_ept
Rednose
Nood1es
rcb054
GEN3LV
RRick
jdm_sixtwo
Jay_P
SurfRaptor
andysp
Bozz
MZRaptor72
Old-Raptor-guy
BfloRaptor
Turning Blue
GCATX
Swacer_2
rwmgd2
Davez134
Pacifico66
HORN HIGH ACES
Russ103
Hard R
WTX
jm77
RockHillRaptor
jayb0ne315
alibo70
someday
Stingray23
970rap
raptor_tecate
shigman
Thatblackraptor
doberman
Dbone
Gibz714
pat247
... and 47 more.
93,222
56,503
DehydratedSurfer
Forums
Accept
Learn more…
