Has anybody run the LVJ Motorsports relay panel?
Kmandoske
Bartlett, IL
FYI, I would never run any kind of light right from the High beam trigger wire. All that I tap into it for is to trigger a relay, it takes a few milliamps to close a relay and does not add any substantial load to the circuit. I have been running my set up for 2 years without issues.
V6Raptor
SoCal
I would like to also say that I’ve been running the Gen 2 Relay since May and it has been nothing short of amazing. What makes the relay even better? Keith’s amazing customer service of course!
The Car Stereo Company
aka grumpy car stereo guy
here, on frf
How is your $375 relay panel different from wiring $7 relay to accomplish the same goal? Trying to understand the value proposition from your solution.
of course it will always be cheaper if you do it yourself. i personally wouldnt buy one, but thats because i know all about wiring and am in the automotive electronics industry, not for any other reason. what keith has done is made a solution thats easy for people who dont have the time to make a kit, or dont have the resources to parts to build it. being able to essentially add 6 aux switches to any trigger you want, is more than just a $7 relay. for a single application, sure one relay will work. but figure in 6 of them, a waterproof housing, main fuse, bolt on bracket, wiring haness, it adds up. as long as you follow the instructions, it removes the possibility of ******** something up for the less electrically inclined people.
Zeusmotorworks
Appears to be a great solution for those not wanting to or not able to reinvent the wheel yet have a need for it. Doubt I ever will, but saved the link just in case.
Ken4570
South Florida
Thanks for all of the discussion on this product. Just ordered mine this evening. I have been relying on the relays built into the fuse block, however the more I read the more I realize Keith's product may save me some $$ down the road.
V6Raptor
SoCal
I’ve had mine for almost 2 years now and no issues whatsoever, other than the itch to keep adding more lights…
pastorwug
Santa Maria, CA
Ditto to ^^^^^^
Works flawlessly.
Ford dealership wondered what it was but then they typically hire Jr. High dropouts.
