Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford SVT Raptor General Discussions [GEN 1]
Going on a 5,000 mile road trip! Any advice?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="14 BlackScrew RR" data-source="post: 1208377" data-attributes="member: 24873"><p>Changing Fluids are in some cases overrated.</p><p>A good example is the Radiator Fluid (Antifreeze) </p><p>If the PH is withing spec,and there is no visible sign of contamination, then there is absolutely no need to change it.</p><p>If the fluid in the Transmission and diff isn't discolored or smelly and is within the specified mileage, the same applied.</p><p>The next time you pass or is passed by an 18 wheeler, the fluids in the Tranny and Diff ( if using Synthetic) is change every 500,000 to 750,000 miles as per OEM spec. </p><p>Our attention should instead be directed to the "BELTS and HOSES" as they are the ones that will fail before the fluids.</p></blockquote><p></p>
[QUOTE="14 BlackScrew RR, post: 1208377, member: 24873"] Changing Fluids are in some cases overrated. A good example is the Radiator Fluid (Antifreeze) If the PH is withing spec,and there is no visible sign of contamination, then there is absolutely no need to change it. If the fluid in the Transmission and diff isn't discolored or smelly and is within the specified mileage, the same applied. The next time you pass or is passed by an 18 wheeler, the fluids in the Tranny and Diff ( if using Synthetic) is change every 500,000 to 750,000 miles as per OEM spec. Our attention should instead be directed to the "BELTS and HOSES" as they are the ones that will fail before the fluids. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Chewie
Jdselig
DTZ
Crywolf4
EricM
MajorAR
aakbar_828
IIAWAH808
scroper
julien194b
Sharpie69
samwelll
FordPerf Addict
2024RaptorR_NOVA
Harry P Ness
77Raptor
IHAVETWO
quattrojim
pirates1456
Dan H
1BAD454SSv2
steveo1103
10SpdsOfFury
MurderedOutSVT
fordfreek
WTX
Waterfowler41
deamer
Reptar854
tangodeltakilo
awd5906
Marlboroman
oswiff
TheButcher
-RRRaptor-
jalenshoojo
04Ram2500Hemi
MotoDad
Chop96
stevenstommyboy1
relak
whitewidow13
FP Forged
alockbox
Tyler James Inc
kalel
Kurt L
got2fly
killallblue
... and 4 more.
93,240
56,530
osten100
Forums
Accept
Learn more…
