Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Problems and Questions Forum
Fuel Cap Leak..
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Drift" data-source="post: 435632" data-attributes="member: 11269"><p>Mil, I think your right it probably would do more harm then good.</p><p></p><p>I got my KIWI yesterday. </p><p></p><p>The code was P0456. </p><p></p><p>Evaporative Emission System Leak Detected (very small leak).</p><p></p><p>I think maybe the flapper door might have bumped and leaked during some spirited desert driving which caused the "Check Fuel Filler Neck" dash note and the check engine light. Once the leak stopped, maybe once I refilled the tank later the engine light stayed on to note and store the code. I cleared the code and it hasn't returned. I'm no certified mechanic and I didn't think an emissions system leak should/would have anything to do with a fuel filler neck. I thought that was typically related to the EGR being a craptastic addition to our automotive fleet but oh well.</p><p></p><p>Will post additional note of engine light returns. I've gone a few hundred miles since yesterday so I think its been "Relegated to the past tense" - Lucky Number Slevin.</p><p></p><p>By the way Dash Command is so stinkin cool. Digital intake temp, coolant temp, MAP, MAF, accelerometers. My new favorite toy =)</p><p></p><p>WIFI broadcast has about .5 second delay on throttle but of coarse data logging doesn't care. With a do over I think I would still just try to find a direct connection instead of WIFI/Bluetoof broadcast. My co-pilot likes the data too = )</p></blockquote><p></p>
[QUOTE="Drift, post: 435632, member: 11269"] Mil, I think your right it probably would do more harm then good. I got my KIWI yesterday. The code was P0456. Evaporative Emission System Leak Detected (very small leak). I think maybe the flapper door might have bumped and leaked during some spirited desert driving which caused the "Check Fuel Filler Neck" dash note and the check engine light. Once the leak stopped, maybe once I refilled the tank later the engine light stayed on to note and store the code. I cleared the code and it hasn't returned. I'm no certified mechanic and I didn't think an emissions system leak should/would have anything to do with a fuel filler neck. I thought that was typically related to the EGR being a craptastic addition to our automotive fleet but oh well. Will post additional note of engine light returns. I've gone a few hundred miles since yesterday so I think its been "Relegated to the past tense" - Lucky Number Slevin. By the way Dash Command is so stinkin cool. Digital intake temp, coolant temp, MAP, MAF, accelerometers. My new favorite toy =) WIFI broadcast has about .5 second delay on throttle but of coarse data logging doesn't care. With a do over I think I would still just try to find a direct connection instead of WIFI/Bluetoof broadcast. My co-pilot likes the data too = ) [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Griffin
Administrator
Members online
REX111
Turbro
Speedhunter
Reptar854
PNTitBLK
MZRaptor72
ToadSmasher2K1
RRR19-Mike
GreenGoblin
FP_RPTR
shigman
WC114
WTX
Raptorrunner
04Ram2500Hemi
IIAWAH808
hawksfan
sonicboom254
Admin.RealTruck
tabbytabb
Monkish1
Griffin
DrTim
ben2jz
GCATX
Turning Blue
pat247
Whoops
CruiserClass
raptorCAT06
Winchester30
Coyote_695
Trail_Rider
Dave T
RaptorAW
kknyrass
nikhsub1
Mark Cormier
pirates1456
JerryJoey
foxrcing07
NJ2020
riv
shank_guru
Sharpie69
Russ103
JohnyPython
DMacDonald
Dan Ordoins
Todd Turbo S
... and 13 more.
93,183
56,468
ngodavid23
Forums
Fuel Cap Leak..
Accept
Learn more…
