Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
Front Suspension Bump Stop???
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ntm" data-source="post: 927997" data-attributes="member: 2412"><p>They do more harm than good on a mid travel setup, like the stock or duals.</p><p>If you've only got 4.5" of compression travel, you don't want 3" of that to be bump stop valving. It leads to inconsistent chassis response when taking multiple larger hits, and requires sacrificing ride quality. Better to just rely upon the poly jounce bushing on the shock shaft.</p><p>The ideal location for a hydro bump is striking the uca right at the upright/knuckle's attachment point to the uca. The bumpstop is interfering with the main valving less here due to only being used in the last 10% of compression travel.</p></blockquote><p></p>
[QUOTE="ntm, post: 927997, member: 2412"] They do more harm than good on a mid travel setup, like the stock or duals. If you've only got 4.5" of compression travel, you don't want 3" of that to be bump stop valving. It leads to inconsistent chassis response when taking multiple larger hits, and requires sacrificing ride quality. Better to just rely upon the poly jounce bushing on the shock shaft. The ideal location for a hydro bump is striking the uca right at the upright/knuckle's attachment point to the uca. The bumpstop is interfering with the main valving less here due to only being used in the last 10% of compression travel. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
trailerjack
CCH
BoostCreep
Gator85
vill
Sharpie69
carlos0001025
Stingray23
bellnghmrider
im33303
3wheelkhalil
GEN3LV
Hard R
xlover
Badboy4fun_wa
93,202
56,485
bjorn-dpc
Forums
Accept
Learn more…
