Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Suspension Discussion and Modification
Frame gusset kit?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Aaron" data-source="post: 1136485" data-attributes="member: 1755"><p>Buy the bump kit if you plan to run hard in the dirt. Bottom line is, in factory config if you run out of travel one of two things will give when you bottom out; your frame or your axle. The factory rubber-dog-toy bumpstop isn't going to slow that axle down and absorb that energy. So depending on what gives you've got a tweaked frame or a busted/bent axle. With a hydraulic bump, you've got something to absorb that energy and keep everything safe. Not to mention help control those nasty donkey-kicks that happen when you do bottom out the back sometimes.</p></blockquote><p></p>
[QUOTE="Aaron, post: 1136485, member: 1755"] Buy the bump kit if you plan to run hard in the dirt. Bottom line is, in factory config if you run out of travel one of two things will give when you bottom out; your frame or your axle. The factory rubber-dog-toy bumpstop isn't going to slow that axle down and absorb that energy. So depending on what gives you've got a tweaked frame or a busted/bent axle. With a hydraulic bump, you've got something to absorb that energy and keep everything safe. Not to mention help control those nasty donkey-kicks that happen when you do bottom out the back sometimes. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Azurebeast
3wheelkhalil
Dudebrodude
east raptor 22
phat_raptor
Brody Goble
Notn41
rasguado
Yc_Raptor
damaschke
4wheelinAZ
LambSVT
Kyle@Apollo-Optics
xturdfergusonx
911r
evoraptor
signalbobby
Hard R
BadWRP
t4arghhh
Todd Turbo S
shigman
93,202
56,485
bjorn-dpc
Forums
Frame gusset kit?
Accept
Learn more…
