Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Maintenance Forum
Dry Ball Joints?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="roadtech" data-source="post: 702043" data-attributes="member: 12197"><p>Hi Folks</p><p>Well this is my first post.</p><p>My 2014 Black Raptor has 11000km as of the past weekend and was time to do my second service, since I have always done them it's not a big deal. I know there's no grease zerks but have been using a grease needle for years and have had good luck using it on all the joints with a rubber bulbs around them. The funny thing about this service was that it was my first lube on the new truck and I put two holes with the grease needle into the bulb and start pumping grease into the bulb, usually grease would start coming out of the first hole I punctured when it comes out I stop and move onto the next joint. So I'm pumping the handle on the gun, I know grease is going in but nothing is coming out but air, eventually some grease came out and I stopped. Of all the joints there was only one Ball joint that appears to have had any grease in it. Some guys may not like the Hole on bulb thing, but of all the years doing this I have never seen water come from any of the punctured bulbs. I work in the Patch in Northern Alberta, we get our share of moisture. Just a heads up guys maybe you own a Raptor with basically dry Ball joints too. </p><p>Don</p></blockquote><p></p>
[QUOTE="roadtech, post: 702043, member: 12197"] Hi Folks Well this is my first post. My 2014 Black Raptor has 11000km as of the past weekend and was time to do my second service, since I have always done them it's not a big deal. I know there's no grease zerks but have been using a grease needle for years and have had good luck using it on all the joints with a rubber bulbs around them. The funny thing about this service was that it was my first lube on the new truck and I put two holes with the grease needle into the bulb and start pumping grease into the bulb, usually grease would start coming out of the first hole I punctured when it comes out I stop and move onto the next joint. So I'm pumping the handle on the gun, I know grease is going in but nothing is coming out but air, eventually some grease came out and I stopped. Of all the joints there was only one Ball joint that appears to have had any grease in it. Some guys may not like the Hole on bulb thing, but of all the years doing this I have never seen water come from any of the punctured bulbs. I work in the Patch in Northern Alberta, we get our share of moisture. Just a heads up guys maybe you own a Raptor with basically dry Ball joints too. Don [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Sergio212
SuprSeb
jake85
Rucku5
JHughes629
pirates1456
Badboy4fun_wa
93,202
56,485
bjorn-dpc
Forums
Dry Ball Joints?
Accept
Learn more…
