Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Exterior Modifications Forum [GEN 1]
Don't call it a bumper. (They don't build them like they used to)
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="andreb" data-source="post: 1246871" data-attributes="member: 16801"><p>People are horrible drivers. My truck was hit three times (lightly) within the first year I owned it. Two times it was a very minor swipe, like the "I don't know how wide my vehicle is" kind. Scrub marks on the outer ends of the bumpers. The third time it was a pretty significant dent in the right rear "bumper half." For $65K I figured Ford would put a real bumper on our trucks but they probably did bumper halves to save weight and the accountants told them to.</p><p></p><p>The dent pushed the inside edge of the bumper half in which moved the outside away from the body. It also wrinkled the top so the bumper cap (that plastic trim piece) won't sit flat. I've been wanting to fix it for a while and finally took a stab at it. Initially I was just going to fix the dent but it morphed into a much bigger project but that's another post...</p><p></p><p>When I realized the bumper was really just a bumper half the job became much easier. I planned to use my hydraulic press to push the dent out and handling the bumper half was much easier then an entire bumper. First step was to pop the top cap off. I used some slip joint pliers to compress the tabs that expand into the holes in the top of the bumper. The job was made easier because two of them popped off when the bumper was hit. A plastic trim tool helps, just apply some upward pressure as you compress the tabs. </p><p></p><p>I think you can pull the bumper half off without completely removing the top cap but I wanted to see what's going on underneath. You'll have to disconnect the back up sensors, license plate lamps and harness tabs to remove it from the truck. Once that was out of the way there are three M10 bolts that hold the bumper half on. I was able to press most of the dent out then did some fine work with a soft faced mallet and nylon body hammer. A wood block helped to refine the edge and spread the load of the press end out. I used a 2x4 on edge as a dolly inside the bumper to form down the crease and square the rolled edge up.</p><p></p><p>The results were pretty good for a novice body/panel guy. Now I see why there is such an aftermarket for complete rear bumpers for our trucks. The OE unit is barely up to the task and certainly not on par with the abuse you can put into the suspension, engine, etc.</p></blockquote><p></p>
[QUOTE="andreb, post: 1246871, member: 16801"] People are horrible drivers. My truck was hit three times (lightly) within the first year I owned it. Two times it was a very minor swipe, like the "I don't know how wide my vehicle is" kind. Scrub marks on the outer ends of the bumpers. The third time it was a pretty significant dent in the right rear "bumper half." For $65K I figured Ford would put a real bumper on our trucks but they probably did bumper halves to save weight and the accountants told them to. The dent pushed the inside edge of the bumper half in which moved the outside away from the body. It also wrinkled the top so the bumper cap (that plastic trim piece) won't sit flat. I've been wanting to fix it for a while and finally took a stab at it. Initially I was just going to fix the dent but it morphed into a much bigger project but that's another post... When I realized the bumper was really just a bumper half the job became much easier. I planned to use my hydraulic press to push the dent out and handling the bumper half was much easier then an entire bumper. First step was to pop the top cap off. I used some slip joint pliers to compress the tabs that expand into the holes in the top of the bumper. The job was made easier because two of them popped off when the bumper was hit. A plastic trim tool helps, just apply some upward pressure as you compress the tabs. I think you can pull the bumper half off without completely removing the top cap but I wanted to see what's going on underneath. You'll have to disconnect the back up sensors, license plate lamps and harness tabs to remove it from the truck. Once that was out of the way there are three M10 bolts that hold the bumper half on. I was able to press most of the dent out then did some fine work with a soft faced mallet and nylon body hammer. A wood block helped to refine the edge and spread the load of the press end out. I used a 2x4 on edge as a dolly inside the bumper to form down the crease and square the rolled edge up. The results were pretty good for a novice body/panel guy. Now I see why there is such an aftermarket for complete rear bumpers for our trucks. The OE unit is barely up to the task and certainly not on par with the abuse you can put into the suspension, engine, etc. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
jusher
8250_RPM
caleb
MZRaptor72
HighSpeedLowDrag
Latchkey Kid
J_OC_Raptor
Powerlies
Gerald
Cronn99
pirates1456
james9
Sharpie69
wesleywest
JFKwasAFK
SeasickLI
dillard09
Punkur67
Spike Spiegel
AJ36_LeadFootG3
Sonicsunspot
MurderedOutSVT
maraim20
jsiv
DrTim
BoostCreep
quattrojim
MechaNick702
Jdselig
Ruger
futurepr3
Pokhj
martinjoa
firemedic343
kocher93
cheese
Gumby
raptordawg1
njhummer18
GCATX
wheelman55
sct
Charliejbr
HORN HIGH ACES
AndrewJ
snt505
TomDirt
TremorRaptor
Pacifico66
darkknight32
... and 37 more.
93,238
56,528
osten100
Forums
Accept
Learn more…
