Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
DayStar 2" Leveling Kit vs Top Perch Shock Adjustment
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="BIRDMAN" data-source="post: 24885" data-attributes="member: 18"><p>Ok, so that spacer looks like it will bolt to the stock spacer on top of the shock mount(see in the pic the top of the shock and 3 bolts? it will bolt to that), then you will bolt the shock through the chassis effectively lifting the truck up off the shock mount 2" from stock.</p><p>[ATTACH=full]172773[/ATTACH]</p><p>when you do the perch mod, you remove the spring, move it's bottom perch upwards(the blue thing) which will basically lift the truck from the spring. the spring is more compressed, the suspension angles change, the wheels get pulled in slightly and the ride gets stiffened.</p></blockquote><p></p>
[QUOTE="BIRDMAN, post: 24885, member: 18"] Ok, so that spacer looks like it will bolt to the stock spacer on top of the shock mount(see in the pic the top of the shock and 3 bolts? it will bolt to that), then you will bolt the shock through the chassis effectively lifting the truck up off the shock mount 2" from stock. [ATTACH=full]172773[/ATTACH] when you do the perch mod, you remove the spring, move it's bottom perch upwards(the blue thing) which will basically lift the truck from the spring. the spring is more compressed, the suspension angles change, the wheels get pulled in slightly and the ride gets stiffened. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
FGHT ON
BHook
WA2012
mubz64
Gdog
PolarZ
ST3V3LU1S
Ryan Voight
nikhsub1
jond
MurderedOutSVT
grleon65
ToadSmasher2K1
kweli19
James O
flyitaway
ksgries
Oldfart
stevelp99
dwood
Stingray23
Gumby
Oaktree202
muss3r86
GCATX
Spydie35
997
k3k0a808
bmiracle
BigSkyGuy
Whoops
Jeff Oldham
martinjoa
Ryed
flips1985
HipHopHonky
ljn21
NorCal Offroad
steveo1103
WTX
RdR2027
H20guy310
uncboysetsfire
drew5580
BigTaco
RogueClimber
jriggsaz
Chupacabras
FP Forged
17baker
... and 50 more.
93,254
56,548
nadz88
Forums
Accept
Learn more…
