Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
Cold weather effects on the suspension.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="MarkT" data-source="post: 111836" data-attributes="member: 3007"><p>One thing about oil viscosity and temperature that is often misunderstood. Multi-weight oils don't really "change" viscosity as much as the viscosity remains stable.</p><p></p><p>Straight 50 weight motor oil thickens considerably at freezing temperatures. Straight 20W motor oil thins considerably at high temps.</p><p></p><p>A 20W-50 motor oil simply doesn't thicken as much as it gets cold... or thin as much as it gets hot. In other words, a 20W-50 motor oil flows like a 50 weight oil at high temps and a 20W at low temps. </p><p></p><p>20W-50 still thickens and thins with temp changes, just not as dramatically as straight grade oils... the viscosity is more stable when the temperature changes.</p><p></p><p>As far as the shock oil in the Raptor... from what I understand it is a very expensive synthetic oil that is designed to work at high and low temps. But, like all oils I know about, it will still be thicker at freezing temps than it is at high temps. As advised... and as you have experienced... in a few miles the oil should warm enough that the "harshness" goes away.</p></blockquote><p></p>
[QUOTE="MarkT, post: 111836, member: 3007"] One thing about oil viscosity and temperature that is often misunderstood. Multi-weight oils don't really "change" viscosity as much as the viscosity remains stable. Straight 50 weight motor oil thickens considerably at freezing temperatures. Straight 20W motor oil thins considerably at high temps. A 20W-50 motor oil simply doesn't thicken as much as it gets cold... or thin as much as it gets hot. In other words, a 20W-50 motor oil flows like a 50 weight oil at high temps and a 20W at low temps. 20W-50 still thickens and thins with temp changes, just not as dramatically as straight grade oils... the viscosity is more stable when the temperature changes. As far as the shock oil in the Raptor... from what I understand it is a very expensive synthetic oil that is designed to work at high and low temps. But, like all oils I know about, it will still be thicker at freezing temps than it is at high temps. As advised... and as you have experienced... in a few miles the oil should warm enough that the "harshness" goes away. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
encyphered
Badmofo82
bakwaas4eva
tst
LayinWatts69
Frogger22
Reptar854
someday
hamster
IIAWAH808
rfranklin1
thatJeepguy
JohnyPython
04Ram2500Hemi
MZRaptor72
raptordawg1
whatthetruck
BushwiickBill
Punkur67
k9lovr
GCATX
Johnny@Apollo-Optics
Sozzy12
PlayNDirt
Seven Twenty
Mossy 150
Rigged_Up_Raptor
Arizona Free
CleverGirl_
WTX
pirates1456
Luchh224
c0b2a
xlover
ToadSmasher2K1
fordfreek
GordoJay
Chewie
BoostedToy
Neens
tcm glx
Skmon
Badboy4fun_wa
Finlay150
YeahYeah
nomis88
RaptorJoe331
2011FX4
Fire Ball
SSWIM
... and 27 more.
93,279
56,566
erikn
Forums
Accept
Learn more…
