Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford F-150 Raptor General Discussions [GEN 2]
"Click-clack" noise from t-case in 4L?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="troverman" data-source="post: 1199776" data-attributes="member: 25003"><p>Anyone else notice some pronounced sounds when the transmission shifts from drive to reverse? I'm wondering if this is part of my drivetrain slack problem. Low range is putting more torque on the driveshafts. Shifting from Drive to Reverse in 2WD also makes a bit of a clack noise. I notice zero vibration or other problem symptoms...but I'm thinking about crawling under and checking the rear driveshaft u-joint.</p></blockquote><p></p>
[QUOTE="troverman, post: 1199776, member: 25003"] Anyone else notice some pronounced sounds when the transmission shifts from drive to reverse? I'm wondering if this is part of my drivetrain slack problem. Low range is putting more torque on the driveshafts. Shifting from Drive to Reverse in 2WD also makes a bit of a clack noise. I notice zero vibration or other problem symptoms...but I'm thinking about crawling under and checking the rear driveshaft u-joint. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
svt54
77Raptor
sajprice86
jdholder
mobob
2013SVTTX
10SpdsOfFury
jhamiltonak
pat247
dannyhdez
kirkb
scsponger31
Reptar854
Evil Peaches
championeaster
hingedthinker
Tin Can Rap
Sozzy12
jekyll537
AZ Raptor
nelsonr103
jp1seattle
Braaaaptor
soheilmos
0341Marine
phat_raptor
alockbox
taquitos
QCRappy
QUIMBOLO
loganl86
FP_RPTR
Latchkey Kid
Brandon Parker
Jakenbake
cjr
Rekkr
HORN HIGH ACES
GCATX
XSTNKT
Swacer_2
Teamwest
Cherry Ghost
WH7
schumacher1111
GaoKS
krmzn
JFKwasAFK
bigmyke84
CecilK12
... and 27 more.
93,205
56,485
bjorn-dpc
Forums
Accept
Learn more…
