Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Lighting Modifications Forum [GEN 1]
clearance lights on the cheap (kinda)
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Blacksheep" data-source="post: 1254338" data-attributes="member: 27127"><p>[ATTACH=full]281507[/ATTACH]</p><p>[ATTACH=full]281508[/ATTACH]</p><p>[ATTACH=full]281509[/ATTACH]</p><p>These are the lights I chose along with the bag for the part #'s<span style="color: Red"></span></p><p><span style="color: Red"></span></p><p><span style="color: Red"><span style="font-size: 9px">---------- Post added at 03:55 PM ---------- Previous post was at 03:52 PM ----------</span></span></p><p><span style="color: Red"></span></p><p><span style="color: Red"></span>[ATTACH=full]281510[/ATTACH]</p><p>This is after cutting off the bullet connectors and butt splicing/heat shrinking on the oem ford connector<span style="color: Red"></span></p><p><span style="color: Red"></span></p><p><span style="color: Red"><span style="font-size: 9px">---------- Post added at 03:56 PM ---------- Previous post was at 03:55 PM ----------</span></span></p><p><span style="color: Red"></span></p><p><span style="color: Red"></span>[ATTACH=full]281511[/ATTACH]</p><p>New VS. old<span style="color: Red"></span></p><p><span style="color: Red"></span></p><p><span style="color: Red"><span style="font-size: 9px">---------- Post added at 03:58 PM ---------- Previous post was at 03:56 PM ----------</span></span></p><p><span style="color: Red"></span></p><p><span style="color: Red"></span>[ATTACH=full]281512[/ATTACH]</p><p>One new one installed<span style="color: Red"></span></p><p><span style="color: Red"></span></p><p><span style="color: Red"><span style="font-size: 9px">---------- Post added at 04:01 PM ---------- Previous post was at 03:58 PM ----------</span></span></p><p><span style="color: Red"></span></p><p><span style="color: Red"></span>[ATTACH=full]281513[/ATTACH]</p><p>Sadly I could not use the new grommets, my old ones are in decent shape though. I rejuvenated them with some silicone weatherstrip lube/conditioner and all worked out.<span style="color: Red"></span></p><p><span style="color: Red"></span></p><p><span style="color: Red"><span style="font-size: 9px">---------- Post added at 04:14 PM ---------- Previous post was at 04:01 PM ----------</span></span></p><p><span style="color: Red"></span></p><p><span style="color: Red"></span>All told I spent about $120 total for all 7 markers. Not chump change but much cheaper than $70 a piece through Ford. Total install was about 2 hours. You do need to be careful with the oem grommets and the lights in the grille. The lights in the grille are held in with stamped hex nuts that thread onto "posts" molded into the grille, I didn't break any but it would be easy to do so. I'll try to post some pics later of the completed project (photobucket is a pain in the A$$). Also, if you prefer Grote has the clear lense markers too at least in one color, I'm not sure if it was red or yellow I saw but I liked the colored lenses. BTW, Grote is the oem manufacturer, if you look closely at your markers they will have "Grote" molded into the lense, which is how I found these. Do a search on Grote's website or search Grote micronova for more info. HTH</p></blockquote><p></p>
[QUOTE="Blacksheep, post: 1254338, member: 27127"] [ATTACH=full]281507[/ATTACH] [ATTACH=full]281508[/ATTACH] [ATTACH=full]281509[/ATTACH] These are the lights I chose along with the bag for the part #'s[COLOR="Red"] [SIZE=1]---------- Post added at 03:55 PM ---------- Previous post was at 03:52 PM ----------[/SIZE] [/COLOR][ATTACH=full]281510[/ATTACH] This is after cutting off the bullet connectors and butt splicing/heat shrinking on the oem ford connector[COLOR="Red"] [SIZE=1]---------- Post added at 03:56 PM ---------- Previous post was at 03:55 PM ----------[/SIZE] [/COLOR][ATTACH=full]281511[/ATTACH] New VS. old[COLOR="Red"] [SIZE=1]---------- Post added at 03:58 PM ---------- Previous post was at 03:56 PM ----------[/SIZE] [/COLOR][ATTACH=full]281512[/ATTACH] One new one installed[COLOR="Red"] [SIZE=1]---------- Post added at 04:01 PM ---------- Previous post was at 03:58 PM ----------[/SIZE] [/COLOR][ATTACH=full]281513[/ATTACH] Sadly I could not use the new grommets, my old ones are in decent shape though. I rejuvenated them with some silicone weatherstrip lube/conditioner and all worked out.[COLOR="Red"] [SIZE=1]---------- Post added at 04:14 PM ---------- Previous post was at 04:01 PM ----------[/SIZE] [/COLOR]All told I spent about $120 total for all 7 markers. Not chump change but much cheaper than $70 a piece through Ford. Total install was about 2 hours. You do need to be careful with the oem grommets and the lights in the grille. The lights in the grille are held in with stamped hex nuts that thread onto "posts" molded into the grille, I didn't break any but it would be easy to do so. I'll try to post some pics later of the completed project (photobucket is a pain in the A$$). Also, if you prefer Grote has the clear lense markers too at least in one color, I'm not sure if it was red or yellow I saw but I liked the colored lenses. BTW, Grote is the oem manufacturer, if you look closely at your markers they will have "Grote" molded into the lense, which is how I found these. Do a search on Grote's website or search Grote micronova for more info. HTH [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
nikhsub1
wyomingraptor
Gator85
oxford37
FoxNotch
Havok_RLS2
93,190
56,469
ngodavid23
Forums
Accept
Learn more…
