Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Problems and Questions Forum
Check Engine Light
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="DROPOUT" data-source="post: 1095156" data-attributes="member: 19928"><p>A dual valve catch can and/or a larger IC should essentially fix the same issue, should it not? Larger IC allowing condensation to better evaporate?</p><p></p><p>We're talking about condensate/oil accumulating on the driver side (engine exit side) and lower inlet tube (where you would tap for the weep hole)</p><p></p><p>If the DVCC does the same thing, you won't have to worry about any loss of boost (even if the marginal/small CFM number doesn't allow you to sleep at night)</p></blockquote><p></p>
[QUOTE="DROPOUT, post: 1095156, member: 19928"] A dual valve catch can and/or a larger IC should essentially fix the same issue, should it not? Larger IC allowing condensation to better evaporate? We're talking about condensate/oil accumulating on the driver side (engine exit side) and lower inlet tube (where you would tap for the weep hole) If the DVCC does the same thing, you won't have to worry about any loss of boost (even if the marginal/small CFM number doesn't allow you to sleep at night) [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
ZorroV
MFouts
fkim119
Danny_Apolos
bakwaas4eva
Zeusmotorworks
Mikemd
0341Marine
SeasickLI
nelsonr103
nikhsub1
RCorsa
MZRaptor72
cschenone
KMO
Butterz
WTX
Chewie
cheese
snt505
Psirus7
MurderedOutSVT
FoxNotch
ToadSmasher2K1
Reptar854
JunkYardDave
dillard09
raptor_tecate
PipeHitter
daytona1783
DDaddy99
ohgeeh
flyitaway
shigman
Marlboroman
pirates1456
GCATX
Coopdaddy
Monte87
CleverGirl_
Frogger22
BigBlackRaptor24
pspc271
IHAVETWO
RaptorJoe331
Advcgh
2022 Ruth
Eisner62
jdholder
Seven Twenty
... and 25 more.
93,284
56,577
spc187
Forums
Check Engine Light
Accept
Learn more…
