Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Audio/Video/Electronics Forum [GEN 2]
CB radio setup
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="grumble" data-source="post: 1265799" data-attributes="member: 25884"><p>for my 2m/73cm install, i used a stake pocket mount from Breedlove Mounts. I mounted the antenna on the passenger side, wrapped the coax in wire loom, and routed it inside the side of the bed, coming out at the front of the bed and into the frame. Up through the frame to the passenger side cabin, there is a rubber drain plug - put it up the drain plug and under the carpet - voila!</p></blockquote><p></p>
[QUOTE="grumble, post: 1265799, member: 25884"] for my 2m/73cm install, i used a stake pocket mount from Breedlove Mounts. I mounted the antenna on the passenger side, wrapped the coax in wire loom, and routed it inside the side of the bed, coming out at the front of the bed and into the frame. Up through the frame to the passenger side cabin, there is a rubber drain plug - put it up the drain plug and under the carpet - voila! [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Bigperm
ToadSmasher2K1
BigTaco
ErixRaptor
elpechedepeche
Sage
mattl600
17baker
thatJeepguy
Frogger22
KMO
SurfRaptor
LambSVT
Badboy4fun_wa
WTX
FoxNotch
Fireman Dave
hyrepower
3Dog
tcm glx
HKX_ORANGECHICKEN
RCorsa
Stingray23
mike Hamel
CruiserClass
wyomingraptor
bellnghmrider
brunorulez
yoxxi
mleaky
kocher93
cheek
skillathon2002
TDBrown
RaptorFan1988
Dameatz
someday
93,291
56,577
spc187
Forums
CB radio setup
Accept
Learn more…
