Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forum Supporting Vendors
5 Star Tuning
Can you run 87 octance with the 91 octane tune?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="tahoeacr" data-source="post: 418312" data-attributes="member: 1310"><p>The real answer really depends on alot of variables. The two biggest factors being how far your tuner went and your elevation. If your at 8,000' el. you could run 87. When tuning on a dyno you set a load on the engine at a given RPM/TPS. Then advance the ignition timing until max numbers are reached. At this point you can keep advancing ignition timing alot before detonation. Where a tuner stops advancing is all in there own way of doing things. </p><p>Here comes the tricky part. All ECU's have factory set parameters that can't (usually) be changed. These parameters are to allow for adjustments from sensor input do to current conditions. So your tuner built your map in a climate controlled dyno room. 68 degrees at sea level. You then go to Death Valley below sea level in 120 degree temps. Your ECU reads the input from Ambient air temp and pressure sensors then compares this to Manifold Air Pressure. Maybe even get an input from a knock sensor. It realizes it needs to back off the timing and change the fuel. If your running 87 it might need to back off the timing farther than the preset values will allow it do to the tuners map having them advanced so far. </p><p>This is a generic explanation. Fords ECU might run differently but you get the general idea. </p><p>Your friend is going off the fact that the knock sensor(s) will retard the timing enough for 87. Fact is probably not a good word to use. It is fact that it will retard the timing. But is it fact that it will retard it enough? Only your pistons and rods will know. As Ford quotes you can run 87 but 93 was used for the 411HP rating on the stock mapping.</p></blockquote><p></p>
[QUOTE="tahoeacr, post: 418312, member: 1310"] The real answer really depends on alot of variables. The two biggest factors being how far your tuner went and your elevation. If your at 8,000' el. you could run 87. When tuning on a dyno you set a load on the engine at a given RPM/TPS. Then advance the ignition timing until max numbers are reached. At this point you can keep advancing ignition timing alot before detonation. Where a tuner stops advancing is all in there own way of doing things. Here comes the tricky part. All ECU's have factory set parameters that can't (usually) be changed. These parameters are to allow for adjustments from sensor input do to current conditions. So your tuner built your map in a climate controlled dyno room. 68 degrees at sea level. You then go to Death Valley below sea level in 120 degree temps. Your ECU reads the input from Ambient air temp and pressure sensors then compares this to Manifold Air Pressure. Maybe even get an input from a knock sensor. It realizes it needs to back off the timing and change the fuel. If your running 87 it might need to back off the timing farther than the preset values will allow it do to the tuners map having them advanced so far. This is a generic explanation. Fords ECU might run differently but you get the general idea. Your friend is going off the fact that the knock sensor(s) will retard the timing enough for 87. Fact is probably not a good word to use. It is fact that it will retard the timing. But is it fact that it will retard it enough? Only your pistons and rods will know. As Ford quotes you can run 87 but 93 was used for the 411HP rating on the stock mapping. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
kevo_lo
Digipax
ScottS23
Naks
elpechedepeche
JohnyPython
CecilK12
DTZ
AmaRaptor
Coyote_695
andysp
Hambone
tm965
Turning Blue
RCorsa
raptorgroyper
BigSkyGuy
TwizzleStix
RobSpring661
Latchkey Kid
CleverGirl_
Rekkr
DRC3
ToadSmasher2K1
mtesni
CSP
RamseyF
Wristdoc
Irregular F150
Dave T
TAC71
wweaver
Wangchung83
thatperson89
GCATX
BoostCreep
adventureduty
BLEEKER
nemx735
EastEndAngler
TheGrizz
Keith88
murffly
MidnightSpecial
HORN HIGH ACES
encyphered
Sozzy12
TheC-Don
KAJRIP
RaptorFun
... and 36 more.
93,201
56,485
bjorn-dpc
Forums
5 Star Tuning
Accept
Learn more…
