Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Exhaust and Cutouts Discussion [GEN 1]
Broken Magnaflow
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="MIAMIRAPTA" data-source="post: 776241" data-attributes="member: 7981"><p>So, after 2 years of solid service, my simple Magnaflow muffler-swap has finally given out on me. Looking to replace it with an MBRP turn-down... but since that will take about a week to receive, I'm trying to figure out how to get it to stop rattling under load. </p><p></p><p>I've currently tethered it with a couple of wire coat hangers to keep it from bouncing around and causing further damage but I'm now contemplating removing everything from the resonator back. </p><p></p><p></p><p></p><p>As you can see, the seam has completely separated on the back end of the muffler. </p><p></p><p></p><p></p><p>My question is, do you think that venting the exhaust after the resonator without a turn-down in place will generate enough heat to damage any wiring/components under the vehicle? </p><p></p><p></p><p></p><p>(I'd remove everything after the connecting clamp)</p><p></p><p></p><p></p><p>[ATTACH=full]239092[/ATTACH]</p><p></p><p>[ATTACH=full]239093[/ATTACH]</p></blockquote><p></p>
[QUOTE="MIAMIRAPTA, post: 776241, member: 7981"] So, after 2 years of solid service, my simple Magnaflow muffler-swap has finally given out on me. Looking to replace it with an MBRP turn-down... but since that will take about a week to receive, I'm trying to figure out how to get it to stop rattling under load. I've currently tethered it with a couple of wire coat hangers to keep it from bouncing around and causing further damage but I'm now contemplating removing everything from the resonator back. As you can see, the seam has completely separated on the back end of the muffler. My question is, do you think that venting the exhaust after the resonator without a turn-down in place will generate enough heat to damage any wiring/components under the vehicle? (I'd remove everything after the connecting clamp) [ATTACH=full]239092[/ATTACH] [ATTACH=full]239093[/ATTACH] [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Irregular F150
tm965
kevo_lo
WNCHSTR96
ryanj
Winchester30
Tbogo
BBR
Sbrewer
Spike Spiegel
fordfreek
Ol_Blue
taquitos
IHAVETWO
Reaper308
FJohnny
Frogger22
Mizzac
Turning Blue
shigman
simplerex
FreightTerrain
FordPerf Addict
mprice1234
Reptar854
LibertyDNP
BigTaco
Therock88
TheC-Don
tcm glx
DFS
MattC1996
MurderedOutSVT
Booth9999
RaptorAU
Zarkmurales
ST3V3LU1S
Rcnfan3117
edglock21
CaptIronside
elking
Gen3Raptor88
Kayslay
pirates1456
elpechedepeche
kevanscpa
WC114
06z
BoostCreep
ToadSmasher2K1
... and 32 more.
93,304
56,593
sdavis007
Forums
Broken Magnaflow
Accept
Learn more…
