Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Problems and Questions Forum
Brake caliper issue?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="PropDr" data-source="post: 303099" data-attributes="member: 506"><p>The suggestion is sound, the fault assumption is not.</p><p>If there is residual pressure in the brake line it would be due to actuators are valves upstream.</p><p>If there is no residual pressure you most likely have abnormal drag on the piston; this could be debris between the piston and the cylinder or, if new, a tight assembly.</p><p>On older vehicles I have seen corrosion buildup on the inside.</p></blockquote><p></p>
[QUOTE="PropDr, post: 303099, member: 506"] The suggestion is sound, the fault assumption is not. If there is residual pressure in the brake line it would be due to actuators are valves upstream. If there is no residual pressure you most likely have abnormal drag on the piston; this could be debris between the piston and the cylinder or, if new, a tight assembly. On older vehicles I have seen corrosion buildup on the inside. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
kosmo
GEN3LV
Azurebeast
3wheelkhalil
Dudebrodude
east raptor 22
phat_raptor
Brody Goble
Notn41
rasguado
Yc_Raptor
damaschke
4wheelinAZ
LambSVT
Kyle@Apollo-Optics
xturdfergusonx
911r
evoraptor
signalbobby
93,202
56,485
bjorn-dpc
Forums
Accept
Learn more…
