Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Lighting Modifications Forum [GEN 1]
best routing for wires
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="NOLA" data-source="post: 964467" data-attributes="member: 19537"><p>Here ya go:</p><p></p><p>If you decide to properly run wires to the rear for bumper mounted lights, or something else, this is the proper way. No disrespect to those who just plastic wire tied it to the outside of the frame, but…yeah.</p><p></p><p>Ok, so get on amazon and get these two items:</p><p></p><p>Cal-Hawk AZGA125 Rubber Grommet Assortment Set Electrical Gasket 125 Piece</p><p></p><p>Gardner Bender EFT-21PN 25-Foot Cable Snake Steel Fish Tape, 1/Pk</p><p></p><p>Twenty bucks total.</p><p></p><p>Park truck and turn wheel to lock left. Get under it and extend the steel tape to at least the length of the truck. The reel part of the tape is a *************, but what do you expect for 11 bucks. In general it works. </p><p></p><p>Get under the passenger side and insert the tape in the hole you see in the pic below and start fishing it to the back. I only had to pull back twice and it went all the way to the back. It will come completely out the back of the frame. At the very back, a few inches prior to exit, there is a solid crossbar, but the tape slid right under it.</p><p></p><p>[ATTACH=full]254017[/ATTACH]</p><p></p><p>I would recommend running two wires (Even if right now you only need one) as a backup for the future, and also putting the wires inside flex-loom before you run them.</p><p></p><p>Electrical tape the wire(s) to the end of the metal snake. Remember to taper off the electrical tape down so that its smooth towards the end and it won't snag as you pull it.</p><p></p><p>[ATTACH=full]254018[/ATTACH]</p><p></p><p>Pull the wire all the way back, and out of the hole near the passenger tire. I grabbed one of the grommets and slid it down the wire and into the hole and with a little bit of wiggling, it fit right in. The kit comes with a butt-ton of grommets, but there is one that fits best, second to biggest with the center already cut out.</p><p></p><p>Plastic wire tie your wires to the factory wire thats right there and just toss up into the engine compartment, you can find it from the top, and then cleanly install it next to the other factory wires, and connect it right there to your uplifter switch wires.</p><p></p><p>NOLA</p></blockquote><p></p>
[QUOTE="NOLA, post: 964467, member: 19537"] Here ya go: If you decide to properly run wires to the rear for bumper mounted lights, or something else, this is the proper way. No disrespect to those who just plastic wire tied it to the outside of the frame, but…yeah. Ok, so get on amazon and get these two items: Cal-Hawk AZGA125 Rubber Grommet Assortment Set Electrical Gasket 125 Piece Gardner Bender EFT-21PN 25-Foot Cable Snake Steel Fish Tape, 1/Pk Twenty bucks total. Park truck and turn wheel to lock left. Get under it and extend the steel tape to at least the length of the truck. The reel part of the tape is a *************, but what do you expect for 11 bucks. In general it works. Get under the passenger side and insert the tape in the hole you see in the pic below and start fishing it to the back. I only had to pull back twice and it went all the way to the back. It will come completely out the back of the frame. At the very back, a few inches prior to exit, there is a solid crossbar, but the tape slid right under it. [ATTACH=full]254017[/ATTACH] I would recommend running two wires (Even if right now you only need one) as a backup for the future, and also putting the wires inside flex-loom before you run them. Electrical tape the wire(s) to the end of the metal snake. Remember to taper off the electrical tape down so that its smooth towards the end and it won't snag as you pull it. [ATTACH=full]254018[/ATTACH] Pull the wire all the way back, and out of the hole near the passenger tire. I grabbed one of the grommets and slid it down the wire and into the hole and with a little bit of wiggling, it fit right in. The kit comes with a butt-ton of grommets, but there is one that fits best, second to biggest with the center already cut out. Plastic wire tie your wires to the factory wire thats right there and just toss up into the engine compartment, you can find it from the top, and then cleanly install it next to the other factory wires, and connect it right there to your uplifter switch wires. NOLA [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Big Blue
Administrator
Members online
jAKe47
dillard09
Comish
ScottS23
Fireman Dave
omegamon1
BHook
Blown00gt
east raptor 22
ToadSmasher2K1
never_summer
1BAD454SSv2
Big Blue
ljn21
NickyF25
PK37
Neckface
NASSTY
93,190
56,469
ngodavid23
Forums
Accept
Learn more…
