Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Lighting Forum [GEN 2]
Baja Designs OnX6 Arc Install Woes... Help?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="4x4TruckLEDs.com" data-source="post: 1271469" data-attributes="member: 24442"><p>As I said in my PM we're not in the harness making business but here's what you'll want to put it together</p><p></p><p>-You can use the existing harness you bought, as that'll save you from having to buy a weatherpack crimper and connectors (about $25 savings right there).</p><p></p><p>So basically take that harness and follow the 3 wires coming out of the weatherpack connector... cut it as far back as you can to give yourself some slack.</p><p></p><p>Next you'll need 2 relays. We buy these all the time. It's always nice to have extra relays on hand: <a href="https://www.amazon.com/gp/product/B011H0MSPQ/?tag=fordraptorforum-20" target="_blank">https://www.amazon.com/gp/product/B011H0MSPQ/?tag=fordraptorforum-20</a></p><p></p><p>Some wire is good to have. <a href="https://www.amazon.com/gp/product/B01C7O82LU/?tag=fordraptorforum-20" target="_blank">https://www.amazon.com/gp/product/B01C7O82LU/?tag=fordraptorforum-20</a></p><p></p><p>12gauge should suffice since you're not going far.</p><p></p><p>Check out this video by ChrisFix for an idea on how to wire in a light bar: <a href="https://www.youtube.com/watch?v=b8GY69Ci7l4" target="_blank">https://www.youtube.com/watch?v=b8GY69Ci7l4</a></p><p></p><p>When he shows hte diagram at 2:06 your upfitter is what is going to 86 (the switch) which is positive voltage. 85 goes to ground (so the relay can be powered). 30 goes to your battery terminal (with a fuse) and 87 will go to the white wire on your OnX6 Bar</p><p></p><p>Now when you turn your upfitter on, you are sending power to #86 which trips the relay, and sends power to the light bar (the black wire/ground, on your light bar will go to your vehicle chasis).</p><p></p><p>So now what about the dimming wire right?</p><p></p><p><a href="https://www.the12volt.com/relays/converting-polarity.asp" target="_blank">https://www.the12volt.com/relays/converting-polarity.asp</a></p><p></p><p>Check that out...</p><p></p><p>same idea basically </p><p></p><p>86 goes to the upfitter</p><p>85 goes to the ground same as before</p><p></p><p>now the difference. Instead of wiring 30 to the battery (+) your going to put it on the ground instead.</p><p>And instead of having 87 to go the light bars power side (white) you're going to the light bars dimmer wire, green.</p><p></p><p>So basically when you activate the upfitter it sends voltage to the 86 terminal which trips the relay. 30 will then pass the GROUND to 87, which is what you want on the green wire.</p><p></p><p></p><p>Make sense? If you've never wired up electronics in a vehicle before it can be confusing, that's why I always recommend have a shop do it for you.</p></blockquote><p></p>
[QUOTE="4x4TruckLEDs.com, post: 1271469, member: 24442"] As I said in my PM we're not in the harness making business but here's what you'll want to put it together -You can use the existing harness you bought, as that'll save you from having to buy a weatherpack crimper and connectors (about $25 savings right there). So basically take that harness and follow the 3 wires coming out of the weatherpack connector... cut it as far back as you can to give yourself some slack. Next you'll need 2 relays. We buy these all the time. It's always nice to have extra relays on hand: [URL]https://www.amazon.com/gp/product/B011H0MSPQ/?tag=fordraptorforum-20[/URL] Some wire is good to have. [URL]https://www.amazon.com/gp/product/B01C7O82LU/?tag=fordraptorforum-20[/URL] 12gauge should suffice since you're not going far. Check out this video by ChrisFix for an idea on how to wire in a light bar: [url]https://www.youtube.com/watch?v=b8GY69Ci7l4[/url] When he shows hte diagram at 2:06 your upfitter is what is going to 86 (the switch) which is positive voltage. 85 goes to ground (so the relay can be powered). 30 goes to your battery terminal (with a fuse) and 87 will go to the white wire on your OnX6 Bar Now when you turn your upfitter on, you are sending power to #86 which trips the relay, and sends power to the light bar (the black wire/ground, on your light bar will go to your vehicle chasis). So now what about the dimming wire right? [url]https://www.the12volt.com/relays/converting-polarity.asp[/url] Check that out... same idea basically 86 goes to the upfitter 85 goes to the ground same as before now the difference. Instead of wiring 30 to the battery (+) your going to put it on the ground instead. And instead of having 87 to go the light bars power side (white) you're going to the light bars dimmer wire, green. So basically when you activate the upfitter it sends voltage to the 86 terminal which trips the relay. 30 will then pass the GROUND to 87, which is what you want on the green wire. Make sense? If you've never wired up electronics in a vehicle before it can be confusing, that's why I always recommend have a shop do it for you. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
kevo_lo
OxWhiteRaptor
nikhsub1
unw153
RennsportRaptor
Old-Raptor-guy
DaveInMn
PipeHitter
BushwiickBill
mashtastic
Drkknght
BHook
ArizonaKevin
CANNON
EagleFive
Astro94
CruiserClass
Crywolf4
Sbrewer
ReddingRaptor
wyomingraptor
harvell326
Dano182
ricetuna
MagneticScrew
Meepmoop
forza423
HookEm
uncboysetsfire
Flynxman
NorCal Offroad
2011_Shelby
james9
WTX
VJDWashington
E90
GCATX
billy8
sjh13
Muchmore
christian26
zefen
brink
DFS
Wristdoc
XtraSpclCrspy
RRick
oplersx
Raptor513
khunter
... and 13 more.
93,523
56,798
CF1975
Forums
Accept
Learn more…
