Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford F-150 Raptor General Discussions [GEN 2]
Auto Start/Stop Not Working??
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="hkguns" data-source="post: 1142514" data-attributes="member: 20725"><p>So you expect Ford to create a custom message for every one of these scenarios? Waste of bits.</p><p></p><p>The system automatically enables every</p><p>time you start your vehicle if:</p><p>• You do not press the Auto StartStop</p><p>button (not illuminated).</p><p>• Your vehicle exceeds an initial speed</p><p>of 3 mph (5 km/h) after you have</p><p>initially started your vehicle.</p><p>• You have stopped your vehicle.</p><p>• Your foot is on the brake pedal.</p><p>• The transmission is in drive (D) or Sport</p><p>mode (enable by pressing the Auto</p><p>StartStop button).</p><p>• The driver door is closed.</p><p>• There is adequate brake vacuum.</p><p>• The interior compartment has cooled</p><p>or warmed to an acceptable level.</p><p>• The front windshield defroster is off.</p><p>• You have not turned the steering wheel</p><p>rapidly or you do not have it at a sharp</p><p>angle.</p><p>• The vehicle is not on a steep road</p><p>grade.</p><p>• The battery is within optimal operating</p><p>conditions (battery state of charge and</p><p>temperature in range).</p><p>• The engine coolant is at operating</p><p>temperature.</p><p>• Elevation is below about 10000 feet</p><p>(3048 meters).</p><p>• Ambient temperature is moderate.</p><p>• You have selected 4X2 or Auto mode.</p><p>• If equipped with Terrain mode, and you</p><p>select auto snow/ice mode only.</p><p>• The trailer is not connected.</p><p>• You have not selected Tow haul.</p><p>• You have not selected Manual mode.</p></blockquote><p></p>
[QUOTE="hkguns, post: 1142514, member: 20725"] So you expect Ford to create a custom message for every one of these scenarios? Waste of bits. The system automatically enables every time you start your vehicle if: • You do not press the Auto StartStop button (not illuminated). • Your vehicle exceeds an initial speed of 3 mph (5 km/h) after you have initially started your vehicle. • You have stopped your vehicle. • Your foot is on the brake pedal. • The transmission is in drive (D) or Sport mode (enable by pressing the Auto StartStop button). • The driver door is closed. • There is adequate brake vacuum. • The interior compartment has cooled or warmed to an acceptable level. • The front windshield defroster is off. • You have not turned the steering wheel rapidly or you do not have it at a sharp angle. • The vehicle is not on a steep road grade. • The battery is within optimal operating conditions (battery state of charge and temperature in range). • The engine coolant is at operating temperature. • Elevation is below about 10000 feet (3048 meters). • Ambient temperature is moderate. • You have selected 4X2 or Auto mode. • If equipped with Terrain mode, and you select auto snow/ice mode only. • The trailer is not connected. • You have not selected Tow haul. • You have not selected Manual mode. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
KMO
The Car Stereo Company
Nyamg
Jeff Glover
Kru
Nacho226
mlax
John Liu
JohnyPython
stevot
0341Marine
sf2360
GordoJay
CruiserClass
Howling_Coytote
MetalDaze
TrucksRcool
Sozzy12
firemanjoe
Raptorman19
Marlboroman
BushwiickBill
kandewinn
970rap
usafjames
cuts
tcm glx
Ryan C
NASSTY
wyomingraptor
BigTaco
abelardoo_12
craptor1792
Latchkey Kid
flyitaway
bigjava2002
DMacDonald
FrankDawg
jdm_sixtwo
thatJeepguy
Wartman
RogueClimber
Gdog
justinh
Thor2j
bdamian
jAKe47
BoostCreep
jbu
... and 19 more.
93,572
56,848
AZBajaRaptor
Forums
Accept
Learn more…
