Thank you for your service, sir.He meant ************, but he's shy and didn't want to come right out and say it.
he he. got to get those fluids out!He meant ************, but he's shy and didn't want to come right out and say it.
I’ve never understood fluid extraction. Make sure the oil is hot and let gravity do the rest. Plus, you’ll get more of the *****/sediment that may be at the bottom of the pan.
Wth the Fumoto, drain right into the empty jug. Let the oil drain and go for a nooner. All the poison is gone.
Before the Fumoto plug, I used to use an extractor to get the first 2.5-3qt out of the engine just so when you remove the oil drain plug, the oil didn't shoot horizontal for 3 feet due to the volume. It was way less messy to remove half the oil then drain the rest in a civilized manner. I don't think there's any way you can get 6qt of oil out of that engine with extractor alone.
After the Fumoto plug install, much easier. Filter is still a ***********, though.
